1973 Plymouth Duster..
you are not supposed to paint all the rubber and door plastics too.lol j/k with ya. i really with you would get rid of that hiious chevey scoop. horrible.lol
Its all good man, I know I was in a hurry. But I can always take some paint thiner or something on a rag and get it off. I like that chevy scoop I think Cowl hoods look good..
cool. if the look suits you, then thats all that matters.lol
oh, about the paint on the upper door plastic; try to get it off asap, as if you use too much chemical to get it off later, it will just melt and make the plastic itself gooey and sticky. the sooner the better
Ok thanks man..
I changed up on motors and I'am going with a 440ci Big block now.. and I ordered the S6 to B/RB Schumacher motor mount kit.. Here are some pics..
Here is the info..
Motor specs..
440ci 30 over
H-Beam Rods with Flat top Ross pistons.
1. 580 Racer Brown camshaft..
2. Team G intake..
3. 950 holly carb with spacer
4. 452 heads with 214/181 and ported and polished.
5.8 qt oil pan
6. Fenderwell Headers with super 44 flows or Dynomax bullets
7. 1.5 roller rockers
8.electic water pump.
CAR
1. 8 3/4 with 456 gears with a spool
2. 15x3.5" and 15x10" weld draglites
3. 28x12.50x15 M/T E/T Streets and 315x60x15 M/T Drag Radials
4. 2 racing seats with 5pt harness
5. 8pt roll cage
6. Disc brake front with long wheel studs on all 4 corners.
7. 10 gallon fuel cell
8. Holley blue pump with fram filter with 1/2 line.
9. No Heat or AC
10. Line lock.
11.No back seat
12. Spring relocation kit with super stock springs
13. Racing shocks in front and the rear..
Transmission
1.727
2.3800-4500 stall
3.Shift kit
4.Reverse Manual Valve body
5.B&M Shifter
I bought some more parts today for the car Manual steering box,Drive shaft,Fuel cell,8" converter..What RPM range is a 8" converter most of the time 4000-4500..
shes gonna be a beast I thought about grafting in a cowl scoop you my 73 its looks good. Keep up the good work
You may want a bigger fuel cell. lol
10 gallons won't take you far with that combo.
I now but the hangout is only about 10-12 miles from my house.If I go to the track I will trailer it.If I go to Richmond/NOVA/Hampton roads to a hangout spot I will trailer it close and unload it and drive it to the hangout.
Today I try'd putting the manual steering box on and with it mounted on the car the steering colum piece is still 3-4 inchs to short and the hole in that is smaller then the rod on the manual steering box. I didn't think it was a differences in the box's..
I noticed it has Air cond, are you gonna keep that? did you get all the parts with it when you bought it back????
