JGC403
I picked up a '76 Duster a couple of months ago with the plan to use it as a Daily Driver. Car originally had a slant backed by a 4 speed OD, but is now powered by a 360. I just finished rebuilding a non-OD 833 for the car and getting ready to install that.
Car is bare bones, no power brakes, no power steering, no AC. Love it.
There is a crack in the driver door on the side above the latch mechanism coming down from the window, I need to get a picture of it. But it causes the window to rattle. I'm not sure If I can try and clamp it and weld it or something. Something is stuck in the driver side key lock and I can't unlock the door with the key.
Engine runs good, but I found a couple issues (horsepower wise). It has a 318 single plane intake manifold. So that will be replaced some day. Seeing the 318 intake got me curious to see what heads are on it. But I haven't had a chance to remove the valve cover to check the casting numbers yet.
Needs blackout treatment behind the grill also.
Front brakes were in rough shape and were not working, so I purchased a set of reman calipers, organic pads, new rubber lines at the calipers and new slotted rotors.
Since the front end is this far apart I was thinking I might as well get new wheel bearings. Also was thinking about swapping the calipers around to the back of the wheel.
First question of many, when swapping the calipers to the back of the wheel, does the caliper brake line need to be longer or shorter than stock?
2nd question, I wanted to check all of the fluids in the car, when it was up on the lift I wanted to check the fluid in the rear axle. I found that there was no plug in the diff cover, so how do I check the fluid? Pretty sure its a 8.25 rear.
