Hi. I have a stock '74 Dart 318 2bbl. I was offered a 340 intake with a 4bbl carb. off another mopar. Not sure if it was from a Dart or other model.
Question is:
1. Will this exchange fit without any modifications.
Yes on the direct part swap question but
NO on the transmission linkage. This MUST be correctly readjusted or use the 340’s parts as the 2 & 4 barrel linkages and brackets are different. A 2bbl linkage can be made to work easy enough.
2. Will there be any noticeable improvement in performance/HP?
Yes but only in the mid range and top end.
3. Will it be worth the conversion?
Depends on the goal or reason. If it is more power, then yes.
Pros, more power for getting on or passing on the Hwy. Cool wide open throttle sound, depending on the two barrel size, better mileage as long as you drive it responsibly.
Con: Some see the conversion as a detractor, a loss of the cars value, so retain all the OEM parts. Added expense for parts you get don’t realize. Carb to transmission linkage as stated earlier, fuel line adjustment or if the correct OEM look, new fuel line. (All cheap but added expense.)
New air cleaner. An OEM 4bbl air cleaner can be pricey compared to an aftermarket open unit.
Temporary loss of mileage. Consistently stepping on the GO pedal really hard. Perhaps even more tire wear? LOL!
I’ll add in recurving the distributor for more power and mileage as a minor expense.
This is just an occasional driver. Not daily, but more than just weekends.
IF you decide on doing this swap and the only occasional weekend use character usage of the car, IMO, it’s not a big deal to do and a fun project. Again, just retain all of the parts you swap. Someone may actually want the 2bbl back.
I am in the process of changing back from a 4bbl. conversion back to the OEM 2bbl. On a ‘66 Charger. I have everything except the intake when I got the car. So I had to search for an intake. It’s not a date matched intake but it will do just fine.
If also agree with Toolmanmike. Those are excellent suggestions.
I’d call them a stage one hot rod step.
A dual exhaust is a very good idea for power and mileage. I also mention a distributor recurving. These two in addition will really help wake up the basic 318. After that, it gets pricey with cam and lifters and/or headers. Going a step further gets more pricey to the point of you might say “Ouch!” when you start seeing g the prices. The next parts are an upgraded torque converter and rear gears. On the high end, a converter is somewhere between (generally speaking) $600 - $800.
The rear gears themselves aren’t too expensive but the process can be a pain and pricey. A lot depends on the rear end size. 8-1/4, 8-3/4?
For now, just do the 4bbl swap, dual exhaust and recurve the distributor for a nice, easy & cheap upgrade that will yield nice results you can notice.
Enjoy
