Shamrock--WV2NC
What's the difference between a 340 and a 340 short block?
Short block - no top end - no heads, intake, etc.
What if it's just the block itself?
I would assume one 340 is complete, and the other is missing heads, intake, and maybe front timing cover. If you go look, I'd be sure to pull the oil pan and look at a rod and main bearing.This guy says he has a 340 and a 340 short block. That's why I'm asking.
You need to ASK the seller. Some people have "funny ideas" of what a block/ short block/ bare block/ long block/ complete on and on. I agree with the definitions posted so far, that does not mean that is what the SELLER thinks he has
Also ask what has it been bored, and if it has any problems, has it been magnefluxed, and DOES IT HAVE any special factory markings, AKA oversize lifter bores. This stuff is documeted in the back "specs" sections of the service manuals, which you can download, free, at MyMopar. No, I don't work there
From this I would assume, (first problem there!) that he knows what he has (not allways the case) and a 340 block is just the block and main caps. I would hope it also has the oil filter plate so can just screw on a filter.This guy says he has a 340 and a 340 short block. That's why I'm asking.
Not where I live, Rob. A short block does not have the heads or intake. A fully assembled block with heads is a "long block", but no intake.A short block is a fully assembled block with fully assembled heads. No intake, may or may not Include a timing cover & have timing chain and gears in it.
ASK!
I would definitely want to see reciepts for the work done and bring your measuring tools to verify the work done is correct.I'm trying to get to see them today or tomorrow. Here's what he has
1. 340 block with crank and caps
2. 340 block fresh machine work .030 over with the pistons. No cam no heads no intake
There is a $1000 price difference between the 2.
Is the extra money worth the machine work and pistons?
Or screw that and go la360 or 360magnum?
Whenever I put this engine in my car, it will be the last. Until I blow it up or something. I almost bought a 360 last week but it was locked up like ft Knox.
I know it's my car and I should do what I want. But some opinions are welcome.
A carb intake and a carb. You'll use your 318 distributor, and wiring. you'll need to figure out how you are getting the fuel to the carb. Mechanical pump has a couple of options I listed above. An electric pump would eliminate the need for a fuel pump eccentric.Do I need the computer to run a magnum? I plan on using a carb.
No, as 318WR said, I used an Edelbrock electrical fuel pump designed for there carbs and no regulator needed. Run 1 hit wire to the pump with there relay kit and the ground wire from the pump to the car body. Done. BANM! EZ fix and constant fuel. Fills the carb bowls in a 2/3 seconds.Do I need the computer to run a magnum? I plan on using a carb.
