I've been running my 372 (340) for 10 years. It is without a doubt the best Mopar motor I have ever owned. So here's the build if your interested. Wisco piston, Eagle H Beam rods, ported Edlebrock heads, Edlebrock Victor intake, Harland Sharp rockers, Smith Brothers pushrods, Crower roller cam, MSD disty locked at 34 degrees timing, MSD Retard box, 750 Holley DP worked over, Mopar Perfromance 360 cast crank, block filler half filled, Milidon pan. The motor makes 540hp and 500tq. It gets shifted at 7000 all day long and I have only had one hiccup with it, a broken pushrod adjusting screw. The motor is in a 3100 # car and runs 11.50's with 4:30 gears and a 904. Its a little to much gear as the trap speed is 111. This is my street car and it raps so fast in first you better be on your toes or you'll be on top of the limiter. Pulls hard all the way to red line and is a blast to drive. There's a lot left in the ET if I were to put in the effort but being a street car it gets the job done.
