360/300hp cam suggestions
maddart
360 LA (Commando) motor-300hp version, what would be the best cam to use in this without head modification. Just cam/lifters/push rods and springs.
Bump. Rear gear ratio,tire size.Trans automatic/stick.If automatic,what kind of torque converter.Peak lift on the heads,should be .460 to .480 lift unported.
Thanks, then the flat tappet cam makes sense.
Would have neen nice if it was a roller. Save the lifters, change the cam and springs and your off.
From what i've researched the early 300hp had a .474" and the 360hp had a .484" cam. The 300hp also had the 1.88" intake valves. Being a hyd. flat tappet i think a regulation Lunati would probably make the most power. I would look to something in this range.....
http://www.summitracing.com/parts/LUN-60403/
Hi Rick,nice cam choice.Some slight bowl work,would pick up 20-30 h.p. and pop.
