Gator77
i have a 400 block at the machine shop.i took him a 440 steel crank that i have .hes telling me it would be cheaper to buy stroker kit. is this true.i already have this crank .also can i use 440 rods or 400 thanks for info
It depends. a balance job can run upwards of 4-5 hundred bucks or more. Mine was 350, using stock rods and forged pistons. add that to the 75 bucks I paid for the crank, plus the 500 for the pistons, 150 for the rings, 100 for the rod bolts, another 75 for the rod bearings and you're at the cost of a stroker kit that comes already balanced.i have a 400 block at the machine shop.i took him a 440 steel crank that i have .hes telling me it would be cheaper to buy stroker kit. is this true.i already have this crank .also can i use 440 rods or 400 thanks for info
most stroker kits are forged. At least the good onesI think the cast stroker kits are about the same for the 400 and the 440. Balance/machine will hurt on a stock 440 crank in a 400 block, just start with a cast stroker 400 crank.
if I were to do it again, I'd just stroke it as well. 440source has a decent stroker kit as well. though it is chinese steel.then it is cheaper .i have 440 rods and crank i guess the machine work will out way the cost thanks time to save up some money for kit
He's putting a 440 crank into a 400 block.Unless you're using insano heavy parts, no BBM crank is going to need mallory, so a balance job should be a couple hundred bucks or so.
What's the purpose of this engine, that's kinda important in determining what parts you need? S/F....Ken M
Really, they actually line bore 400 block (and clearance block for all the throws) to fit a 440 crank journal? That sounds way too costly than turning a 440 down or even buying a cast stroker crank. You think you can build a 451 stroker that will bust a cast crank? Challenge round......! Think about what goes into turning a 440 crank into a 451: Turning down the journals, turning down the counterweights, then balancing the whole thing. What you have left is a 50 year old crank that has hours of machine time on it and takes fillet main bearings ($$) and needs $$ in tungsten to overcome the weight taken out of the counterweights. And if you sunk all that money into a cast crank instead of an old forged piece...? You would be money ahead with a purpose built stroker crank, cast or forged.Is he going to turn the 440 crank mains down to 400 bearing diameter?
Or bore the 400 block and caps to 440 bearing diameter?
They did it that way back in the day because you couldn't buy one, now you can just buy one and be done.
Don't forget about turning and polishing. The 440 crank has to be turned down to fit in the 400 block. Plus you're not using the same rods that came with that factory crankshaft. Nor are you using the factory pistons. Lots of weight difference with those two things involved.
