autoxcuda
- Joined
- Apr 6, 2007
- Messages
- 8,838
- Reaction score
- 3,793
I thought the cam was:
Summit Racing SUM-1789 Summit Racing™ Camshafts | Summit Racing
TQ numbers look really strong right at the start at a pretty low rpm.
Cam specs from Summit:
Basic Operating RPM Range:
1,500-5,200
Intake Duration at 050 inch Lift:
216
Exhaust Duration at 050 inch Lift:
216
216 int./216 exh.
Advertised Intake Duration:
272
Advertised Exhaust Duration:
272
Advertised Duration:
272 int./272 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:
0.454 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:
0.454 in.
0.454 int./0.454 exh.
Lobe Separation (degrees):
110
