autoxcuda
- Joined
- Apr 6, 2007
- Messages
- 9,527
- Reaction score
- 5,062
In my 416, I run the comp 274-S which is a solid cam near the 275 hydraulic.
274-S 236/242
Duration @ 0.050" int 236 / exh 242
Lift int 0.502" / exh 0.511"
LSA 110
Intake centreline 106
* Edelbrock heads -ported, pinched reduced (some ports have brass tubes) and matched to headers and intake.
* Icon dished forged piston
* 340 block 0.030"
* 9.7:1 static compression with 65cc measured chamber heads
* MP M1 single plane intake cleaned up inside and matched to heads
* BG Silver Claw "750cfm" double pumper that some have flowed to 900 cfm dry. Probably too big
* TTI 1-5/8"x 1 3/4” step headers
* Automatic
* close to stock 340 converter
* 8-3/4 sure-grip with 3.23 gears
* small diameter tires that makes gearing equivalent to 3.73 gears w/275/60/15 tire)
It's nice on the street. I think the carb might be too big. Got to watch the tune for low speed take off stumble (my converter is probably too tight too)
274-S 236/242
LSA 110
* 340 block 0.030"
* Automatic
