$50 Craigslist 360 EXTREME budget rebuild??
Stock cast open chambers have that wide flat area at about .090" deep. I can't say how much that will vary; I've only measured a few with the same idea in mind....open to closed chamber conversion. If you have the chance jpar, measure how much depth is actually left there.
I've seen them as deep as .115-.118 and about .100 seemed to be normal. The stuff is so old that it's all been cut two, three or a half dozen times by now.
I'm pretty sure the 360 motor hasn't been apart before, you can usually tell there's plenty of signs but you know that.
10-4
I've already decided I'm not going to spend multiple hours porting these heads. I'll spend an hour on each one opening up under the seat a little bit, but I'm not going crazy with it. I still have to plug all the smog holes on the exhaust ports, lap the valves, and install the springs.
I wonder about testing the valve springs ? Where? How? Don't do it enough to buy one, rent? A NEW REDNECK TOOL!!?
I'm using the ones from the 318 because they already have ran with that cam and they're way cleaner. But I thought I remembered one being loose ??
1.88 weigh more then the 318s intake valve........how much lift is the cam? maybe just add a .020 shim under the valve for just in case.......
Harbor Freight digital micrometer says 1.27 on base of cam and 1.57 on lobe. About a 450 lift I assume ?
Well, when the wife runs the rev's up and floats the heavier valves on that higher than stock lift and cam ramp rate (not only possible but fairly likely?), the pistons way down in the hole may well save things from crashing together. FINALLY! A virtue in those low compression height 318 pistons!
Yes, you look to be about right on the lift....that is a pretty standard max lift range for the stock valvetrain.
Jpar, if ya need shims let me know, I bought some and ended up with way too many, I can send them your way, no charge.
If your around .450 lift, stock springs are just fine (360 or 318).
I'm only going to say this once, not going to argue with the nay-sayers:
I've ran .474 lift cams on stone-stock 318 heads, and 360 heads, and NEVER had coil bind or valve float shifting at 5500 rpms or under. Some of it has to do with how fast the duration ramps up and slams it shut. You will NOT get the advertise lift with stock rockers.
  • J par, you can take your springs to a machine shop and they can check the pressure, probably for free if you been there a few times.
Thats what I was thinking - taking them to a shop.
I was never worried about coil bind that's for sure. Same cam same Springs same lifters same Push rods. It's just as I was recalling that Thought one of the Springs seemed a little loose at install height like I could turn it too easily.
That should never be, you had something else going on there. That spring should never be relaxed enough to be loose.....
