64 Valiant V 200 aftermarket tire / wheel sizes.
ChazRam
1964 Valiant V200
Carol Stream Illinois
64 Valiant V 200 on this end. Want to run aftermarket wheels and tires. Looking for staggered look having the back of the car raised. What size combo will fit without rubbing? Going to also see if anyone on the site is selling what I'm looking for?? I do have a full set of small bolt indy slots here i can use that are 14X6 and 14X7. Just need to know specifics as tires are 900 bucks and want the right size, thanks in advance.
Chas
@66340SEDAN has a 66 and has messed with that. My Dart may have different sized wheel wells but I have ran 15x7 with a 4" backspace and 235-70's on the aluminum wheels and 225-70's on the black wheels.
What size wheels and tires are in the 2nd picture and what kind of wheels are those?
Tire size on post #2. The wheels are Halibrand knock off's. Made in China and sold at the Mopar Nats years ago. They were a generic brand
I think the wheel well sizes are going to be very similar between a 64 and a 66. Here's mine, 245/60-15 in the rear, 215/65-15 in the front. They all clear with no issues.
My rear rims are 15x7, small bolt pattern. I can get a finger between both the spring and fender lip.
I was able to get a 255/60/15 with factory steel wheels using 8 1/4 rear '65 Valiant. You must check your own car. They vary from car to car, even the same year.
The rears are 15x7, the fronts are 15x6. I don't recall the BS but they are standard Wheel Vintiques from Summit.
Nice ! My goal is 245s/60/15s in the rear. And 225/60/15 in the front. Glad to see you fit them.
