66 valiant 273 engine
jairs340swinger
New Member
bechtelsville
what is the difference between a 180HP 273 ENGINE COMPARED TO THE 245HP 273....and if the block casting# is different from one to the other..engine is out of a 1966 valiant
Biggest difference is in the pistons and hotter cam.
yup 10.5 to 1 dome top pistons, slightly hotter cam, dual point distributor, and 4 brl Carter AFB. The chrome unsilenced air cleaner, wrinkle finish valve covers, and fender badges are cosmetic parts of the complete commando package, along with a resonator in the exhaust.
The Commando engine should have 273-4 on it.
From the EarlyValiantBarracuda website => http://www.earlyabodyforum.com/board/messages/394/2207.html?1165590450
·235 hp Commando 273 V-8 Engine
· Carter aluminum 4-barrel
· 10.5:1 compression dome-top pistons
· high lift, high-overlap cam
· dual breaker points
· solid lifters
· special intake with unsilenced chrome air cleaner
· black crinkle Hemi style valve covers with aluminum fins
· chrome Hemi style PCV valve
· Hemi style ignition wire grommets
That could be misleading since all 273 engines had solid lifters and adjustable rockers
That is also one of the prettiest mopar engines ever imho.
I agree but all that pretty carries a hefty premium. If I added up what I've spent gathering a complete commando package I'd be ashamed to admit it. The wife would faint LOL
