Just acquired a 66v100 2 door post.
pulled apart the connections at the firewall-- cleaned up with sandpaper/contact cleaner (noticed some melted plastic)
(downloaded wiring diagram)
Found on the engine side the dk blue wire(connection "Q") has been hot & melted the casing, I cut the harness apart & replaced this wire.
dropped dash gauges-- same dk blue wire melted-- going to splice in replacement tomorrow.(right behind ignition switch melting starts)
What is next step--
temp gauge moves slightly right at 1st start then returns
fuel gauge no movement(ground strap intact at tank)
ammeter moves but registers slight discharge.
so far that is the only melted wire, I'm cleaning up old splices & nicks as I find them.
The back of the gauges looks ok, I'm going to remove & scuff the nuts on the back. thanks Lawrence
What is next step--
