[WANTED] 67 A Body heater complete setup wanted
Yea it sounds like I’ll be putting the a/c unit back in then, just to use it as a heater in the winter. The a/c wasn’t hooked up anyway. Thanks for your input.
I'm not sure how much different the firewall is? I know from having to work under dash with ac it is a ***** from the tight quarters.
If it's an ez swap to non ac I would do it.
The main difference is the hole for the fan motor. Cutting the standard/heat only firewall for the a/c box, larger fan hole, adding holes for refrigerant lines, etc.., is easier than filling these holes back again for standard/heat only box.
Add in the difference at instrument bezel, it gets expensive to change either way.
for gedimaster-1
That 68 model climate controller ^ doesn't bolt up to or work correctly behind the 67 b'cuda instrument panel.
