Finished up all the wiring!! I can actually start the car from the driver's seat for the first time in 2 years. The electric fans are all wired up too. They turn on at 180 and off at 170. Also installed my new 1 wire alternator. I pretty much have the brake system done also. Just need to find one banjo bolt that I lost and I need the brass T that goes on the rear end. Then I started working on the clutch linkage. I modified the z bar to clear the headers. I ended up moving the down leg 9/16" towards the engine to eliminate any interference. It turns out that the ball stud that was sold to me isn't for an A body. It looks like it's for an early B body. I chopped it up and welded it back together and now it works perfectly. I made my own backing plate for the other ball stud and welded to the frame.
