crvtec90
I was under the impression that the o2 was not used to calculate fuel until closed loop is achieved (engine up to operating temp). It does matter which side the sensor is plugged in. There are pre- catalytic converter sensors that measure O2 before the cat and post sensors that measure after the cat to make sure the cat is doing its job.
They usually refer to them as Bank 1 Sensor 1 (B1S1)
and post cat Bank 1 Sensor 2 (B1S2)
Bank 1 is the side of the motor with cylinder 1. I have no experience with this particular system however, and could be completely off base. Thought I'd share. Love your build, and look forward to seeing it burn rubber.
