[WANTED] 68 383 gts kickdown linkage
Sure is I have the carb rod and upper pivot but the rest was gone
I have a bunch of b body and e body stuff but no idea what it actually is supposed to look like
Linkage picture
Thanks I have the upper part I need to see the down rod and lower bell crank and rod to trans
Let me know I think it needs to be from a big block a body
Upper pivot, carb rod and the long rod to lower pivot are a body specific.
It’s not length I think angle is what is different and it’s not adjustable from what I gathered
OK, but they came off a 383/727 68 GTS parts car I purchased. Does anyone have a picture of the complete linkage set up
The upper pivot ball stud should be on the same side as the carb rod
That’s pretty much the key piece. The other pieces could be used if necessary. I’m not sure if I could find it but I had a list at one time of the part numbers of each piece.
well the engine was out of the car and these parts were in the trunk, I might not have it assembled correctly. It may be correct just needs to be reconfigured
This is the upper pivot and carb rod that was hanging from The throttle cable when I pulled this turd out of the bone yard
