'68 Cuda Gas Tank Sending Unit
MrJLR
Built, not bought
Menifee, California
I'm seeing 2 different units while looking to buy a new one....
Some are 5/16" outlet and some are 3/8" outlet.....
Anyone know the correct part I need?
Thanks!
Jeff
:coffee2:
If the sender tube was 3/8.. the entire line coming to the fuel pump would also be 3/8. So, raise the hood and look at right frame rail. Unless you car was a big block build, I expect you'll find 5/16 tube and hose connecting to fuel pump.
And by the way... If you see the factories crimped clamp on that short rubber tube while looking there, you're seeing a rubber hose that is nearly 50 years old. It'll be a good idea to replace that with new.
It was originally a /6....now a 318 - swapped by the P.O....
And just a word of caution, the newly manufactured senders usually are not accurite. Search around for threads about this if it's a issue.
be prepaired to tweek on it several times.they are known to be VERY INACCURATE
thing about it is you get one end accurate then the other if off.pos.another rocket science **** up.if you have the orig.i would send it off the get rebuilt
Just hook up the new one when it is out and go full/empty with the arm, adjust it then, not rocket science to do.
Shouldn't have to. Just jack up the rear, remove one of the wheels. Remove the sending unit wire and fuel line to sender. Use a flat head screwdriver and hammer to tap the lock ring counter clockwise until it turns. Remove sender and install same way.
I'd bet your float is full of fuel. If the car doesn't have to be on the road that same day, you can most likely repair the float by letting the fuel drain out and then soldering up the pin hole in it that allowed fuel to leak in. Then use an ohm meter and check the resistance while you move the float arm up and down. Might as well replace the sock while you're at it. Think they can be had for $6 on rockauto.
My dart it does not, KrazyKuda will know.
We just replaced the whole tank and sending unit on our 71 Valiant, it's been a while since I tried to do them in the car.
I think I've been able to wrestle them with the tank in, you just have to flip them around to get the different bends of the tube out.
