Texas69dart340
=P~Awesome Build! Looks great!
Be careful with that turbo location. They will need a scavenge pump to pump the oil out of the drains and back to the pan, and that might even be questionable.
I dont, but I do like BBQ!:-DDo you like BBQ's strut rod bushings?
dude this is looking amazingi had an idea for you tro think about. cut out fog light holes in the bumper and put the turbo inlet thru there. so they are kinda camoflauged lol idk how sleeper you want this tho lol
Beautiful work.
I cannot believe the number of members that drag race their cars..that sport has just about died around here. I'm impressed.
Ian.
Hi guys, I am aware of the turbo location and drain back. I am going to use a remote reservoir and pump the oil back into the pan. Its pretty easy and has been done many times before. Squires turbo systems is probably the most well known to do this. I went down to the shop today to finish up. Here are some pics.
Cool. Why are you hard mounting the turbo to the frame? I hope just for position? Keep the 90' bends as short as possible. To many turns will cause lag and unwanted spool time...
I am working with my engineering team at work designing turbos for my Cummins...
Thanks
The motor is solidly mounted to the car with motor plates so its pretty irrelevent what the turbos are mounted to. Thanks for the advice, I have experience running this very set up.
I haven't been on here much, life took an unexpected turn and my time has been diverted to another section of life. I hope to get back on it here this summer. I see your close! I can't wait to see the smile on your face after that thing gets sideway at over a hundred!
