HemiMark
Ever get your ideas mixed up ???? ( the old vs the new idea)
Yes, this morning I was thinking I was getting laid but instead I just made coffee.
I knew those farm animals were going to be an "issue"
Here's a shot of the lower hose utilizing the heat shrink clamps. I made the cut directly over the Upper Alternator support so it would act as a anti-wear strip to protect the actual rubber hose against potential rub-thru since it rests directly on the aluminum bracket.
Awesome.
The pic should be larger![]()
Can't wait to see this thing in person again!
Let me know whenever you guys are coming this way...until then, here's some more pictures for you to look at. I spent a few hours today adding a couple more cool little detail parts...I really hated to drill a 1" hole in the firewall but it had to be done for the coil wire pass-thru, I mounted the flange on the inside to reduce the look. Unfortunately some bolts have to be seen, so I'm using some unique fasteners to make them low profile and not so visible, I also used them to bolt the hood and trunk on. I also picked up a nice coolant recovery tank that I have to make a mounting bracket for but looks very clean on mockup, Finally I attached the bare Aluminum steering wheel rivets, The wheel came with Black also but I wanted some contrast.
Sorry for the small pic's.
Almost the size of a Rum and Coke...28oz. It's dimensions are 10"x2"x3".Everything looks great............. How big is the overflow tank?
I think that may be on the large size for a Rum & Coke but I will be the last person to argue about it!Almost the size of a Rum and Coke...28oz. It's dimensions are 10"x2"x3".
You've really got me at the Diet Cherry Coke.....I love that stuff!....Just fill the tumbler with Ice add 4 shots of Rum and top it off with a can of Diet Cherry Coke.
........ I don't know what Mark who seemed to be caught in the act was doing, but you can clearly Dad with all the tools of the trade mixing up his favorite concoction.
Denny hardly ever imbibes.
as long as he (Mark) isn't doing whatever he does before he makes cheese sandwiches....we are good.
......but we upgraded to big tumblers....Just fill the tumbler with Ice add 4 shots of Rum and top it off with a can of Diet Cherry Coke.
I like what I see.....as usual, all the mods are well thought out. Never afraid to alter things if a better way is discovered.
How many sets of drink tumblers were scrutinized before you hit on the best ones?
There's just some things I'm well educated on....Trial and error...the best way to learn, although I do feel bad for the spilled and wasted Alcohol that was sacrificed in the name of education .Excellent data analysis on the cup selection.
