74 Duster, resto mod 6.4 conversion in Australia
there's tons of tyre to leaf spring clearance there, i've scalloped the leaves with a grinder for tyre clearance before, lol. every little counts :thumbsup:
neil.
Great response as i wanted to know how close you can go as was unsure if they would scrub under load if the rubber buldges. So by what you are saying nothing to worry about?
Diff bolted in with the Kaltracks and calverts all hooked up. Spring perches not welded on as will do this when figuring out pinion angles etc Ill start work on the gas tank next i think
So pulled the balljoints out of a another set of upper arms and threads are cooked. So before i go the tubular route i have purchased some pressed arms that run the bigger balljoint. As problem i was finding is many pressed aftermarket arms were small ball joint or a custom balljoint to work a certain brake kit etc.
Sold the old 318 and diff for 1200 bucks so happy with that to create some more space. Just figuring out who to build my 904 and then ill drop it off. About to start making the k frame dolley so can put motor in and out with box connected.
As mentioned before, the threads in the UCA aren't sharp like a nut or something. Even when new.
Here is a weld in ring that Speedway sells that could use a stock UBJ. Note how shallow the threads are.
Steel Upper Ball Joint Sleeve, K772 Style
The UBJ not grabbing anything and dropping through is an issue for sure and not sure what you are seeing on the "new" set of UCA's.
Yea i did consider buying some of these and fitting them into the old arms. Spoke to a mopar guy here who will paint my car once body is all done, he said very common when taking the old ball joints out cooks the original threads and then arm for the bin.
Be interesting to see the quality of the new pressed arms i purchased. They advertise as a heavier duty steel etc.
simple mod for more space and ease install / removal.
HDK replaces the lower portion of the 2-piece shaft with a piece of 1" DD that is held solidly in place by two set screws and a new sturdy bearing. No longer a need to loosen the column once in place
lower section of 3/4" DD slips into the 1" DD and cut with approx 2-2-1/2" into the 1"'DD. The 3/4'' DD shaft will slide easily in / out but is held securely into the 1"DD
use a Borgeson vibration dampener / u-joint to connect to the 3/4" DD shaft to the OEM shaft spline.
the shaft size is now 3/4" solid vs the OEM hollow 1-1/8 od and makes install or taking off or completely out a breeze.
I couldn't get the photos to load in messages, so the bourgeon coupler is just ever so slightly smaller than the coupler that fits the PST steering box. Looks to be just over 1.5mm difference not sure what that is in inches lol. Do you think i have the wrong coupler or a machining issue?
Edit just looked a 11/16th is 17.5mm and 19mm is 3/4 so that would make sense to why. (I think the standard manual mopars are 3/4 as well) I have contacted PST to see if they can confirm the spline size
View attachment 1716486188View attachment 1716486187
I believe you are on the right track, I would say you have the wrong coupler.
As I remember (????) you did not know what spline or shaft size you had but told me you were using a PST manual steering box, so I believe I got the shaft spline and count from the PST site?
let me know what PST says. Are you sure you have a PST steering box?
I hope so as thats what i purchased it as lol, i have contacted Kanter auto who now own or merged with PST, to find out the spline size. I can also see if the standard coupler fits it once i pull the saft out. If it does then its 3/4. Either way mate the pipes now fit with clearance. If i have to buy a 3/4 so be it as happ as knowing i dont have to rebuild pipes haha
OK, It is beginning to appear it may be an OEM steering box. Please keep me posted.
Denny
Denny
No worries its a 16/1 box, unless pst now use standard spindels on their boxes. It came with the shaft adapter that gets you from manual box to power column. Pretty sure its not oem
