Johnny71dusty
Do all a904 small block trans bolt right up to the 90s 3.9 v6 ? If so what years ? I want to help a guy put one of these motors in his old mopar
What flex plate ? One from motor or one from trans ? Also I see no 3.9s came with 904s but see guys on here say they boot right up . I just can't verify any years or models .As long as you use the "old" flex plate. I would use the 68 and newer to avoid the odd ball convertor hub and input spline.
Is the V6 going to be running a carb or the factory EFI?Do all a904 small block trans bolt right up to the 90s 3.9 v6 ? If so what years ? I want to help a guy put one of these motors in his old mopar
Who knows lol . We not even looked if there is a carb/ intake for them aftermarketIs the V6 going to be running a carb or the factory EFI?
This is great thank you . I'd like to use that 904 variant I think. All the trans I see that went with them are in trucks but they don't list it as a 904 but some weird numbersNo need to verify make and model of a donor car or for parts.
The bell housing pattern is the same on the back of the block and the crank is in the right spot. Any small block transmission will bolt right up. The flex plate from ether will work.
The V6 engines came with the overdrive trans which were the 904 variant. A-500, RH 42? I keep forgetting that number….
The early 904’s have an odd spline count of *I think* it was 18.
(I should remember this since I have one and it was a bear to find a converter for it.)
Just make sure the front of the converter fits the rear of the crank. It should be super close fitting.
Below is a picture of the hub on my 727 converter, the measurement may not be dead on as it was a bit of a pain to do where it sits. But that’s the idea…. That hub sits in the rear of the crank.
The stock flex plate uses small (*Again I think) 5/16 bolts. ES to source from Summit and other places. If you need to order a flex plate, just say it’s for a 904.
At one time Mopar Performance did make a intake of the 3.9 V6.a carb/ intake for them aftermarket
The 3 speed 904 or 727 will work fine behind that V6. If you're keeping the EFI you will have to notch the bellhousing for the crank sensor. Also, you'll have to elongate one of the torque converter mounting holes in the flexplate so it can bolt to the earlier style torque converter.Is the V6 going to be running a carb or the factory EFI?
So what year trans should I get ? If using a 2000 3.6 ?pre 68 spline count changed from 67, iirc.
I confused a 3.6 with the 3.9, my bad. At this point, I don’t know if it will fit.So what year trans should I get ? If using a 2000 3.6 ?
3.6 or 3.9 ?So what year trans should I get ? If using a 2000 3.6 ?
First post3.6 or 3.9 ?
A 3.9 is basically a 318 with two cylinders chopped off.
Comes in magnum and la depending on year
I'd heard people say this and other people say that isn't true. But either way if it bolts to a 904 I'm happy with that. I wish we had a carb intake to run that way but no signs of ones out there for saleFirst post
1) the 3.9 was carbureted 1 year only, '87 model with a 2bbl.I'd heard people say this and other people say that isn't true. But either way if it bolts to a 904 I'm happy with that. I wish we had a carb intake to run that way but no signs of ones out there for sale
The switch to the 42RE transmissions, from what was originally the 42RH (aka the A500), coincided with OBD2. So generally speaking, 1995 and back was the RH, 1996 forward was the RE.I'm not sure if the switch to RE coincided with the sw to Magnum, but likely it did.
