A new battery for my Demon
French demon
South of France
My old battery died recently. RIP
As my '71 Demon is totally stock, I wanted to install something looking good.
In Europe, it's logically impossible to find a battery closely resembling to a '70 Mopar one.
I had to make my own "group 24" battery.
I had to start with a black colored battery with a flat top.
I purchased this one :
Impossible to escape to the foldable handle, all modern batteries have one :(
So, I glued the handle into its housing and covered it with a large Mopar sticker.
Then, I used a kit containing self-adhesive dummy green plugs and green stickers.
I also made new positives and negative cables close to the original ones
The final result.
Not an exact reproduction of the '70 Mopar battery, but I think it looks better than the horrible modern batteries. :D
Francois
The final result.
Francois
Great work! It may be different in Europe, but in the US; starting batteries are rated by cold cranking amps (CCA's) instead of Amp Hours. Storage batteries (for electric carts and the like) have thinner plates and generally cannot handle the large current draw required to start an engine. Please correct me if I'm wrong about this. Again, great job!
Honestly, I don't know. The CCA are not indicated on european batteries. Only Amp/H.
I referred to the 1971 Chrysler chart which preconizes a 60A/H battery for Slant 6 and Small-block.
My old battery was also a 60Amp/h and the engine did always start without any problem.
The final result.
Francois
So here is my best reply spelled as it sounds while I butcher the French language Trey Bon Francois!
Translated that looks great, well done!
Great work!! You can be very proud of that car and what you have done to it!!
Batt looks Great!!
Thanks a lot, Mike.
I love my Demon, yes. The only car I would change for is a '70 Barracuda convertible, but this remains only a dream. At least, for now :rolleyes:
Next step for the Demon, a new radiator. I have an original '71 Chrysler one waiting for a rebuild.
Francois
Hi Sublime
Phonetically, it's good. Better to write : "Très bon"... And yes, you can translate it in english by "Well done".
Thank you for your support
Francois
I did the same with the stickers but I didnt bother doing the green tops. It looks much better that a regular battery.
Today, my Demon got a good cleaning, including the engine bay.
I also removed the white covering on the roof.
Back to black
Not too bad for a 51 y.o. vinyl top
Moi aussi je dit tres bien est bon travail
Dan
Well done and nice work
