where is the shear sleeve on your bushings pictured, They do not have them installed only the sleeve between the washers.
You forgot that your adjustable strut has a swivel built on it. And you actually believe your self that the strut rod holds the LCA in place on the K-member due to stiffness . Your making a fool of yourself with some of your comments . Do you press the pin in the bushing and keep them lubed up? is there room for lube. LOL. Doesn't most of the kits require the outer sleeve and inner sleeve to be kept in place.
How about those poly strut rod bushings with no shear sleeves. I guess they worked just fine on your car also.
You know? Back 10's and thousand miles ago before you they sold adjustable struts . You can love them all you want. To me and many others that have a grasp on reality they are scrap for street use.
I have just seen to many cars come here with problems and not because they were installed wrong. I didn't install any of them. Every one but you installs them improperly. You know "They pick things up ! they put things down" Again they are ripped before you put them in. Figure it out.
Did you ever drive your car on Pa. rolling hills with all the pot holes we have in the north east. They don't stay in place the arm moves away from the K-member.
That picture you have the arrows on was a waist of your time. You show nothing on it but your ignorance. Look closely at the pictures of the used bushings. Do you see the steel molded into them. the Poly bushings do not have that . They shear off almost immediately.
An adjustable strut is a good item. But not when used in conjunction with lubed up poly struts. By your own explanation of what holds the arm in place would not be there. The arm has a swivel built on it. The arm could pivot off the pin. Are you blind?
Hotchkis 14385: Adjustable Strut Rods 1967-76 Chrysler A-Body | JEGS
Wow I cannot believe how you came up with the arm cannot move. Put a socket swivel on the end of an extension and then put the ratchet on the other end. Hold the swivel and see if you can move the ratchet with the extension. I cannot believe how ignorant some of you are
The picture I posted from another thread was a reference on how the bushing can be off the pin while still in place with the strut rod attached. not as something that I installed. Something you mentioned that holds the control arm from doing what is pictured
There were a couple of members here last night and your explanation of these bushings and how they work was brought up. They all said the same thing. You will never understand logic.
What holds the control arm on the pin? It cannot be the strut. That is common sense. It would have to be the torsion bar clip.
Those are called spacers your arrows are pointing to that keep the washers at the correct distance apart. Slip the spacers out and and where are the sleeves? I don't see them. The spacer goes on the rod between the washers . The shear/wear sleeve would be against the Hole in the K-member with bushing material between the sleeve and the spacer. You really don't have a clue do you?
And what stops the K-member from shearing off the material between the edge of the k-member hole and the spacer between the washers. The one piece rubber on the early struts would wear through over time . That is why they upgraded them to two piece and added the steel,
The poly style material just without the sleeve shears off. The second picture of the bushings without the spacer slid through shows the steel is built into the bushing . The spacer is not slid through. If you want I can go get a spacer and slide one through so you can see the two at one time.
Notice the steel molded in the bushingx below the poly bushings do not have.
Here are a few quick explanations of a strut rods function I acquired via the inter webs.
The first is from Global West Suspension. (Ford)
1. “The strut rod, also called brake reaction strut rod, attaches at the front cross member under the radiator and extend back to the lower control arm. The strut supports the lower arm from moving fore or aft during acceleration or braking. The factory uses a rubber bushing to attach the strut rod to the cross member.
The strut rod also performs an alignment function; it adjust caster. Caster provides straight-line stability and is used for improving corner entry. Caster is also contributes to a self-aligning action after the car comes out of a turn. If the bushings go bad, the car will wander, dart during braking, and cause the toe to change (thus creating more tire wear).”
Hmmmm. I’m sure their just out to procure a few more $ from all the “ignorants”....
The second is directly from from Firm Feel’s website, in reference to their a-body adjustable strut rods.
2. “We built these adjustable struts to properly locate the LCA (lower control arm). If you are running urethane or nylon LCA bushings and urethane strut bushings
your strut length is now more critical to insure the LCA doesn't slip back or forward on the pivot pin. Otherwise your LCA inner pivot will be " floating," so the front end alignment (toe setting) will not stay put.
You want positive caster AND you want a stable toe setting.
We recommend you preassemble your LCA / Strut assembly and sweep it up and down to make sure every thing move smoothly and the LCA inner pivot stays pulled up snug in position against the LCA pin shoulder, then assemble the rest of the suspension.”
Wow! Deja vu eh? It’s what everyone has been saying all along. Weird. Is Firm Feel really a respected vender in the Mopar community though? (Sarc)..... Pretty sure most folks here would say absolutely! Ignorant?
The third description is simply from hotchkis’ website in reference to their a-body adjustable strut rods.
3. “Hotchkis Sport Suspension 14385 1967-1976 Dodge A Body Adjustable Strut Rods. Dramatically improve the cornering performance traction and steering response of your Dart Demon or Valiant with Hotchkis Sport Suspension Adjustable Strut Rods. Designed to positively locate the lower arm these strut rods will improve responsiveness and driver control. The adjustable design features 5/8 in. high articulation rod ends CNC bent brackets and lightweight TIG-welded 7/8 in. tubing. The part is finished off in a lustrous nickel look powder coated finish blending form and function. Features: TIG-welded Lightweight 7/8 in. Tubing Rigid High Quality 5/8 in. High Articulation Rod Ends. CNC Bent Brackets High Quality Hardware Lustrous Nickel look powder coated finish. Benefits: Positively positions lower Arm and Improves Responsiveness. Adjustable design with Rigid 5/8 in. High Articulation Rod Ends. Improves Caster Removes unwanted play and excessive movement in the front suspension. Bolt In Installation. We recommend upgrading to our 21366 Polyurethane lower control arm bushings for use with this part.”
Again? They must be trying to trick “blind, ignorant” enthusiasts into blowing their hard earned dough. I’m guessing that hotchkis challenger that’s pulling a G in those auto cross corners has SUPER BIG torsion bar clips... you know, so they don’t run over the front wheels when they slip right off the control arm pivot pin. Snake oil I’m sure.
Here is a pic from the Hot Rod article titled “How to Rehab Mopar Front Suspension”
4. https://www.hotrod.com/uploads/sites/21/2017/01/mopar-lower-control-arm-attachment.jpg?fit=around|29:16
Why doesn’t this “ignorant, blind” car lover simply slide the attached control arm/strut rod assembly into the k-member and on the pivot pin, one at a time? I mean, the strut rod in no way keeps the control arm from moving forward or backwards right? How could it with that swivel and all? Duh
Lastly, here is a video on YouTube, produced by MOOG of all people. It shows how to inspect strut rod bushings. You’ll probably notice that the second line in the video states that the purpose of a strut rod is to control fore and aft movement of the control arm....
5.
Holy crap! Your absolutely right! A worldwide conspiracy involving all of the accredited, aftermarket suspension venders in an effort to exploit our “blind, ignorant”, automotive hobby, loving asses!
It’s your turn Oldmanmopar, break out that Cobalt ratchet, swivel socket and extension. It’s time to save all the helpless idiots from the things that only YOU know. I feel a life changing YouTube tutorial coming on. Even if it does insult 7/8ths of the populace.
Make vulcanized rubber bushings great again!
Wow quite the debate went on here. I think both of these guys are partially right. I do not agree that the factory lca bushing holds the arm in place, but I do not believe that the strut does either. IMHO I think they were on the right track about the torsion bar, but not the clips. As was mentioned previously, a suspension is a system.Are there any poly strut rod bushings out there that are the correct thickness and that don't push the wheel-end of the LCA rearward as compared to stock?
I recently installed nylon lower control arms bushings, and rms strut rods with
A heim joint on the end. During the install I did indeed see how the arm can just slide back if the strut length was not correct. I adjusted my struts while pivoting the arm up and down to find the arms natural position up against the pin. I think the more correct terminology is that the strut locates the arm in the correct location.
But assessing the weight of a vehicle and the braking forces involved, there is no way that I believe that the strut keeps it there.
The strut is at an angle. It's purpose is not to keep the arm up against the pin, but to keep the arm square to maintain toe pattern.
This is mentioned in the Mopar chassis book. Your toe setting may get done at an alignment shop at rest, but the struts are what keeps the toe setting dynamically while driving or braking.
Once the correct strut length is determined to position the arm against the pin, your torsion bars would be installed and tensioned.
The bars are supposed to be driven in right up against the arm further locating the arm against the pins. It's a system.
Once you tension the torsion bar enough to support ride height, think about how much the front end of your car weighs. All that weight is concentrated on those six torsion bar hexes. You just try to slide that bar back with all that load on it. It ain't gonna come out.
I think of the clips like the cotter pin on a ball joint assembly.
If you installed the joint correctly, and torqued the nut to spec, it should never come undone. The cotter pin is just an insurance policy against complete disassembly, but by design should never really be needed. I think both those guys are both partially right, and to some degree partially wrong, but this too is just my opinion.
Cheers to you and stay healthy during this time.
Oh I shouldn’t even bother.
The torsion bar can slide back and forth too. Most cars have a good 1/4” or more between the end of the bar and the clip.
Here you go. A ~1/4” gap, so nothing to positively keep the bar from sliding back. Which means it can’t keep the LCA from moving back either.
Now, torsion bars don’t slide around freely because they’re usually loaded. But keep in mind that as the suspension works up and down the load on the hexes varies quite a bit, and at full extension of the suspension there may be very little force on the hexes depending on how the adjusters are set. The bars can move. If the anchors are greased and the bars are fully unloaded they can slide right out by hand. Doesn’t usually happen if they’ve been in there for 20 years, but I’ve done it on bars I’ve installed recently.
The strut rod locates the LCA. Not the rubber in the control arm bushing, not the torsion bars. If the LCA was held positively in place by the rubber in the bushings or by the torsion bars, there’d be no need for the strut rod at all. And if there was no need for a strut rod, you’d better believe the factory would have left them out.
Most of what I said you just repeated. I agree the adjustable strut locates the arm, that's how I did it too. I agree the torsion bar clips do not hold the arm and that they usually do not even touch the torsion bar. Whenever I have removed a torsion bar I have always found the best way to get all the tension off is unbolt the upper ball joint so the arm can drop even lower.Oh I shouldn’t even bother.
Well possibly, but it's also possible that the gap between the clip and the bar is intentional to allow for expansion. As some of the posted pictures show, Chrysler left quite a space there, so it must not be an issue if everything else is installed correctly.Is there value in adding shims to tighten the gap between the spring clip and the torsion bar?
Also, do you know of any poly strut rod bushing that are the correct thickness and locate the wheel side of the LCA in the correct location? Seems like if one would want to run poly strut rod bushings, they'd either have to modify the bushing, or use adjustable strut rods.
My point is that the torsion bar imho works as part of a system along with the strut to keep the arm on the pin. Those bars cannot slide back easily at all even when partially unloaded.
I am not trying to get into a heated debate with the two of you.
I am just saying that I think both of you were partially right in different areas. But that is just my opinion.
Stay healthy my friend.
