1968 Dart 270
Got my new standard regulator today. Amazingly stamped on the bottom is MADE IN USA. Says it on the box too and it's not a vintage NOS piece.
Haven't had a chance to test it yet with work and all. Got the regulator today. Yes rebuilt parts aren't as good as they once were. They are charging 88 dollars and a 100 dollar core now for a rebuilt one,but it has a lifetime warranty so they will keep swapping it out if it fails..at least that's somethingJust some general bla bla. It may have failed, becuz, china. The transistor may not be able to handle the field current. I'm sayin that it may not handle the field current of a PROPERLY operating alternator. Additionally, Not all alternators draw the same field current, and with the poor reputation of rebuilders, VERY possible that a rebuilt rotor draws more than it should
And then you could have a rotor that has a possible short, also causing it to draw extra current.
So if this new regulator doesn't solve the issue,the alternator would be the next in line? What i don't get is why it was fine all this time.drove it to work. Went to go home then it's doing it starts doing it. At idle the gauge is dead center. Touch the accelerator and it climbed near the end line and stays there until you left off the gas. Then it returns to dead centerWhat concerns me here is this
Did the plastic covered regulator fail because of a quality issue, or some other cause. Why did it fail to break the circuit?
One thing I suspect is that none of these were made to handle the current draw more than double of the factory expectation. So the field current draw is one possibility when the alternator has been replaced.
You need to get into the shop manual and measure alternator field current draw.
I've owned the car for about 2 years. Driven it around had the 7 1/4" rear go bad,replaced it with 8 3/4" and started driving it again leaking steering box and all. The alt meter would always rise when it accelerated,but within the normal operation parameters on the meter. It just started doing this on the way home that day.You need to get into the shop manual and measure alternator field current draw. There is a procedure, not hard. Those regulators may well not be able to handle the current. This also depends on if you somehow got a real big alternator, like 55A or larger.
Yes I will do that. Is it common for these alternators to fail and start putting out a ton of voltage and overwhelm the regulator? My finned mopars have generators. Never had this issue beforeAlso, maybe, just for kicks, output voltage.
All we know at this point is BIG, which is not very objective.
– Eric
In my experience the most common failure with the alternators themselves has been to loose one winding or one diode. The the alternator makes less power at all rpms, but is most noticible at idle. At idle the battery is discharging to keep things running, then with increasing rpm there is enough power to run the car and recharge the battery.Yes I will do that. Is it common for these alternators to fail and start putting out a ton of voltage and overwhelm the regulator? My finned mopars have generators. Never had this issue before
OR what would it do differently from an NOS American made regulator. Say, NAPA Echlin, real American made Standard ignition or even NOS factory Chrysler? I have an NOS NAPA regulator on mine that's been there since 2019. I don't even think about it. Now watch it burn to the ground tomorrow.The question is why.
What would a board made by one of us do, or how would it be different, then the board FBO is having made, or from electro-mechanical internals?
The ONLY way that could happen is if, on an isolated field alternator, the green terminal end of the rotor grounds internally. But on a 69/ earlier set up, the regulator is supposed to be controlling field current, so the only way it can get field current is if the regulator is supplying or an internal problem is causing the regulator to feed "full field" current. I'm sure this can happen--the pass transistor for the field is shortedYes I will do that. Is it common for these alternators to fail and start putting out a ton of voltage and overwhelm the regulator? My finned mopars have generators. Never had this issue before
FBO's unit is not adjustable; the design I'm working on is. Also, instead of using a conventional fiberglass circuit board, I'm having the circuit printed directly on an aluminum heat sink.The question is why.
Replaced the regulator, seems to discharge more at idle and shoot over to the right light the other one at light throttle. Difference is now that the headlights flicker when accelerating the ammeter needle flickers back and further when it goes toward the right. Here's a photo of where it's goingIn my experience the most common failure with the alternators themselves has been to loose one winding or one diode. The the alternator makes less power at all rpms, but is most noticible at idle. At idle the battery is discharging to keep things running, then with increasing rpm there is enough power to run the car and recharge the battery.
The next most common problem is the replacement alternators themselves. The rebuilders often mixed and matched parts. At least in the old days some shops only replaced parts that tested bad. Now, most shops just buy replacement one size fits most parts and throw them in. There still are a few places that will rewind a rotor, but that's a rarity. Anyway the result is we end up buying alternators that draw 6 or 8 amps through a circuit that was designed for 3 amps. One of those items in the circuit is the regulator.
Then there are the problems that aren't the alternator or regulator. Over 50 years of outdoor exposure and occassional abuse result in resistance in the circuits - especially at the connectors. The resistance causes the regulator to see low voltage, so it provides more power to increase the system voltage.
Nope,there's this thing called work that I have to get up and do at 6am this morning so that means getting up at 5am. So no,I didn't screw around with it further last night.dig out my mulitmeter,etc. It will have to wait until Sunday. The fun never ends.Still no voltage readings?
- Eric
That is not true as stated, but unwanted resistance in a circuit and at higher amperage demand certainly DOES cause HEAT and accelerates failure, whether terminal mates, crimps, wire insulation, etc.Resistance will cause huge amp draws on demand.
Good luck
Yep,connections are clean and on tight. The battery has never given me a problem before. I changed the regulator 6 days ago. Ran the car for a minute to test it. Backed it out to do that,then drove it back in. Either there's got a be a voltage drain or the battery was damaged. Guess im going to have to pick up a cheapie meter after I charge the battery and get it runningWell that's weird. Make sure it's not just a loose battery connection, etc.
