yellow rose
Overnight Sensation
I calculate about 11.3..
Ok. Then like I said. A 9. Then I gave you a couple of other options if that is too hot.
^^^lol...
I used a Autolite ar3934 racing. Switch to an NGK-8 now a 7.
Last time I was searching around with plug stuff it was that run on that I was getting when my octane was running out of my fuel tank. I was starting with plugs but ended up just tossing a gallon of race gas in and solving the problem and then ended up with the number 7 in there and they're fine. I'm not searching for an eighth of a tenth of 1/16 of a millimeter of extra time off my quarter mile....
^^^lol...
Do you think those 208 intake valves are going to fit in a 318?The TF heads are gonna add power to just about anything you put them on.
Do you think he'll pull this old tired 318 out to notch the bores for trick flow heads...lol..They will be close. You may have to notch the bore. I know a 2.05 fits, but even then I'd notch the bore.
BTW Jpar, I ordered new Champion, Autolite and NGK plug catalogs today. Just because I hate using cross reference charts. It's easier if I just have the plug manufacturers own heat range charts to look at.
Trick flows have 208's...2.02 valves fit the 318.
Recommending someone trying trick flow heads on a tired old 318 even for laughs is one of the most ridiculous things I've ever heard of...
here's my point would you recommend to some new guy on the form to buy trick flow heads for hos tired old beat-up 318? I realized he said it's just a temporary deal till he gets them on his big motor but seriously?...2.08 valves will fit a 318 without a notch, but as YR said a notch is a good idea.
Its another "whats on jpars mind " post hehe.Is this the TrickFlow post, procomp Speedmaster post, aluminum head post, or cast iron vs aluminum.
I’m old and easily confused. Lol
What!? I'm wrong impossible!!..I went back and read his post and did not see where it said the 318 was worn out. Besides, I seem to remember a guy on here who put a tunnel ram on a worn out 318. So, why not good heads?
