SNKEBIT
Spending $$ on Mopars
I guess my ideal tow vehicle would be an old Dodge with a new drive train. The 'Lil Red sort of had to stay a 360 though.
Yup, but the 360 in the LRE was plenty stout.:burnout:
Do you remember where you bought the switch for the blower motor?
Mine in my 78 is sticking so bad I am afraid its going to break.
Last week I loaded up the Duster and hauled it to a glass shop to have the windshield installed. The boss was gone and the one worker there told me he could save me money if I returned on Saturday and helped him install it after hours. I was to call him 'early afternoon' on the 28th.
On Saturday (the 28th) I waited until 12:30 in the afternoon and called him up. He answered but said he was out of town and I should have called earlier. I was a biy miffed but figured that I could wait until he returned later. I told him to give me a call when he was ready. - If not Satrday evening, then on Sunday.
It's now Monday and I still haven't heard back from him. The truck is still hooked to the loaded trailer. I'm starting to consider putting the windshield in by myself. I don't have any of those big suction cup tools and I'm a little leery of handling the glass without an extra hand. In order to work inside I'd have to push the 'Lil Red out into the driveway. I ran out of propane for shop heat on Friday and didn't bother to get the tank filled because the truck was still hooked to the trailer. (I've got an 80 gallon tank)
I focused my attention on non-car stuff over the weekend but I don't want to be held up much longer. The clock is ticking and I know that when Spring arrives most of my time will be occupied by obligations that will prevent me from making progress on these projects.
What a bummer! I wonder if he really knows his stuff and maybe it might be better just to have the BOSS do it and be done with it. Sometimes I find it a pain to try to save a few bucks and seldom does it work out as I had wished.
I have a pair of the suction cups but never use them on rubber set glass.
I trust my hands as the best tools as they won't let go of the glass till I'm ready.
You can do it yourself if you take your time and are careful.
The most important thing to remember about installing windshields is
glass won't bend without breaking.
You will need a 1/8" nylon cord saturated in 100% silicon spray lubricant.
Keep the rubber gasket wet also.
If you have or plan any painting going on in your shop use dish soap rather than the
silicon spray as it will cause problems later for your paint. The soap will require more wettings as you progress because it can dry up and get sticky when it needs to be slick to make it go easy.
A nylon board may be used very carfully if needed. Use only the open flat palm of your hand
to pat glass into place.
If you are planning a after seal between the rubber gasket and body use liquid butyl.
It comes in a metal can with a screw on cap. There is a trigger pump that screws onto the can
when you remove the lid. Make sure you heat the can of sealant so it will be liquid enough to flow out the small needle tip. I use a heat gun or propane torch.
C.R.Lawrence sells the sealant and pump for the can.
If you have any questions before you start, just send me a pm.
The outside door handles arrived today. I don't know why so many people seem to think that the reproduction handles are bad. These seem flawless to me. It only took a few minutes to install them but it seems as though I've misplaced the linkage rods so they aren't functional yet. I called my usual parts buddy looking for those rods and he's got some but he'd have to pull them from a truck that isn't a parts vehicle. I'll have to make some more calls to see if I can find a better option.
I might have some. let me check.![]()
Crap - that 2nd picture had me scared for a second! I thought maybe the winter was a little tougher than you let on when I saw the Cuda with a hole in the roof, but then realized it was your funny car shell! As Emily Litella used to say on SNL- "Oh, thats very different -never mind".....
Maybe time for my annual eyeglass exam.
Man I thought I had a lot of tags to renew! You need to send that Cuda or RR to Fla so they can be driven!:toothy1:
Great info!:cheers::cheers::cheers:I have a pair of the suction cups but never use them on rubber set glass.
John, I know I have some. It's been below zero today and I wasn't going out in the back 40 to dig for parts. How fast you need them?
