AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 24,941
- Reaction score
- 12,294
I don't blame you for not liking that cam.
The cam card pic isn’t all that clear for me.
I thought the 274/282 was @.006....... but maybe it’s a “4”.
Maybe the OP can verify it for us.
Also, the hand written duration number under that...... looks like .016....... but again, I can’t really make it out.
ok but which method did you use so we can share
all I can see is your cam is quite a big bigger than slantsix64's
both magnums and stock compression, carbs
timing? timing curve?
if you have a 4 way timing set I'd try the 4 degree advance and see what happens
here's some cheers
cheer, cheer, cheer
here's some cheers
cheer, cheer, cheer
