B-1 BA small block heads
kingvern
Clarksville, Michigan
Just wondering what a set of B-1 BA heads are worth. They would come with 1.5 crane gold roller rockers, M-1 single plane intake, pro systems venom II 950 carb. This stuff was brand new 20yrs ago with only test stand run time at machine shop.
Hey Vern. I remember the heads and stuff. Are the heads to intake a standard pattern or W5? What about the exhaust? Do you have the valve sizes and flow specs? Just for a comparative reasons for yourself against other heads. The problem here is now the Trick Flow head is an excellent offering OOTB as cast. With high flowing ports. With this, it becomes hard to sell a better head for what it is worth.
https://static.summitracing.com/global/images/chartsguides/t/tfs-6141t784-c00.pdf
Cost starts at $1019 per head;
Trick Flow® PowerPort® 190 Cylinder Heads for Small Block Mopar TFS-61417801-C00
Up to $1199;
Trick Flow® PowerPort® 190 Cylinder Heads for Small Block Mopar TFS-6141T784-C00
Then, maybe the Harland Sharp rockers @ $868
Head bolts @ $95/studs @ $190
Up to $1199;
Rumblefish360 the intake is standard. The valves are 2:08/1:60 exhaust ports are D shaped with standard bolt pattern, Koffels place said use standard headers but cut the tie bar between the ports for spark plugs. They are raised heads. Not sure on flow numbers. No porting just intake port match.
Page 69-71 will give you info on all the Brodix heads for Mopar.
The B1-BA gives you the opportunity to run T&D rockers which are great pieces. Not sure you'll need them for a streeter.... but for a race car they are perfect.
The Trick Flows are nice but I'd sooner have the Brodix. But that's me.
https://brodix.com/wp-content/uploads/2018/11/BRODIXCatalog2019Web.pdf
