I will call Brewers next week to see if there is another back up light that will work. Pntastar69, what would you suggest to put on the end that would not hurt the inside if it came off. I am going to pull the switch and look inside and maybe stick a screwdriver in the hole with the tranny in reverse to see how far in I need to go here. I have been working on the starting issue. Will check this out tomorrow. Thanks guys.
