Basic Performance
Dan the man
missouri
With what I'm wanting to do with the car I get. Wouldn't a 600 edelbrock carb, performer intake, headers, speedmaster cylinder heads, I figured using those would be more cost effective than rebuilding a set of 50 year old cylinder heads. A custom ground cam so that I can get the best out of my combination. Would this be a good way to go? Hopefully I'll have the car by end of next week. If the car has a good running 318, and has bolt ons I'll leave it like that.
Yes contact cam manufactures for their advice, They do Cams 24/7/365.
See Rusty Rat Rods. "guide to hot rod bliss"
In article section
Dan, why don’t you just post these questions when you have a dang car. This way you can focus and stop the forum from chasing there tails around trying to answer “What if I have….”
So far I see, I should have a car soon. It might have a 318. And the ram favorite your asking over and over. What should I do to it?
Im looking forward to your catch.
Here is a dam good US made camshaft and great price on ebay ### that would compliment your build.
I suggest;
NOT, a 292/292/108
Nor a 240/248/112
I see no good reason at this point, for a custom cam, cuz we don't even know what you Compression Ratio will support.
And
You never do mention here, what you are actually wanting to do....... lol
Take your time.
I suggest;
NOT, a 292/292/108
Nor a 240/248/112
And
Take your time.
Freakin A! AJ! Freakin A!
I ran that cam (MP 284/484) in my 340, liked it! IIRC they called it the "Roadrunner" cam. "...The MP 284/.484" cam was considered by Mopar as the 'wildest' cam to be used with a stock convertor and gears..." I ran it with 3.91 gears and an MP 175K convertor. Would break the rears at will. I think the mocdern version of this cam (maybe the one listed) would have less overlap for power brake operation.
The Crane 15006 is a full 10*@.050 less than the MP484 cam, and it’s on a 112lsa vs a 108.
It’s a few steps smaller/milder cam imo.
I agree with that. The 112 works for power brakes. Otherwise it’s not what I’d want to run. I ran the next step smaller Crane (272) which I did like but it wasn’t very torquey out of the hole in the low compression mill. It was nice once driving down the road. That cam fell into “General Performance.”
A duration @.050 of 224/226 or less falls into this category IMO. Cutting 8 or so degrees downwards allows more Hwy.-ish gears to be used.
