Crutchybilt_Per
Active Member
Well there are inherently a few obstacles. Honestly the idea came up because the lack of blocks available to begin with. That being said we have 14k wrapped up in two blocks for a couple of customers that bit the bullet and we pulled the trigger on a pair of BMP blocks. Don't get me wrong, they are works of art, but 7k a block after final machining is a lot of money for anyone. So we thought about getting into casting blocks of our own design, that quickly turned into the fear of copyright infringement which would be a huge issue. So if you are going to change the design of the block enough to get away from the previous stated issue, why not go for broke and share some of the luxuries that brand x guys have and that's killer top end parts. The intake would be a trick for sure, but its all do able. We finished one big block and its going low 9's, the same platform with better heads and it would be an 8.50 or better piece with no real hard work. An engine is like a human body, the bottom are your legs, the cam is the brain and the top half are your lungs, you can have great legs and be smart, but if you cant breathe you wont be going anywhere very quickly lol. Thank you for your input sir.Interesting... I realize you're not aiming for the restoration market with your concept but rather for the guys tweaking as much HP as they can out of their motors. - So the purists out there may cringe at the idea of putting Chebby parts on their cars but most likely the blocks would be actually using aftermarket heads from those companies like Brodix - not Chevrolet. Once people wrap their heads (no pun intended) around the concept that they're not committing sacrilege adding parts off a GM to their cars they may accept it.
There isn't a Mopar owner that hasn't realized how much more expensive it is to build a Chrysler than brand X. - But most of us bite the bullet and pony up because of our devotion to our Mopars. Head selection has hurt us. Most aftermarket companies have been less likely to devote the engineering costs for Mopars because the market is smaller.
Intake & exhaust may be your biggest obstacle. - The low cost solution may end up awfully expensive.
Good luck with your idea and I hope it pans out. Why would it matter to some if they were telling folks they were running Brodix instead of Edelbrock or Trick Flow?
