Birth of the Blue Missile
Andrew....you left out the "with great boldness" part.
Kirk out.....
Denny, Hemi Mark, the rest of the brothers & I are so fortunate to have been
chosen by Andrew to preview his dashboard. I feel so blessed!
That design was pitched to me but... if you think I'm going to let my wife steer from the right hand seat you're nuts!
Andrew
Here is todays progress, another dozen little things to make and tweak then I can weld the large scoop to the hood and have yet another thing to BLOCK!
Andrew
Now we need video of the hood in action like the deck lid wing lol thanks joe
I went through the mechanicals and made a couple of new brackets. Im trying to get the motion to be smooth, Its a little bit jerky right now, but all the functions work quite nicely. I got it welded to the hood, shot with a good coat of epoxy primer, and inside the shop for a little hammer work and filler.
Andrew
Andrew
:thumblef: Outstanding!
Im still blocking the hood/scoop, aiming to get it back on the car this weekend.
In the mean time I have come up with a badge for the scoop. As of now it will be for a 440 small block, but the number can easily change. At the back of the burner there will be Mike LeVally style blue- true fire flames spilling on to the hood and the scoop. Now I just have to find a local painter that can do that. The last pic is an example of the real thing from Killer Paint.
Andrew
After another go round with the filler and complete sanding, I primed and will have to sand and apply glazing putty for the little things left. It will still be a while before it gets put back on the car.
l Andrew
Andrew,
It always amazes me what you come up with it looks great.
The only other thing I see you could do to the scoop is add the crease down the center of the scoop, but I am sure you though about that already.
Keep up the great job.
i am so curious to see this thing finished and what the curb weight will be. I bet in wiring alone you are at 500lbs. Amazingly creative and innovative. Keep it up.
Ill take and post one after the holiday, im ashamed to say its very jerky in its movement but it locks up and down right it needs to.
Andrew
