72ScampTramp
Scamp Tramp
I just mixed some fiberglass body filler and applied. It was about 50 degrees outside. This was in my garage with out heat. Was it too cold?
If it gets hard you are good to go.
....thats what she said lol.....sorry couldnt help it......If it gets hard you are good to go.
....guess you beat me to it ,i shoulda been paying attention lolthat's what she said.
sorry couldn't resist![]()
that's what...ahh never mindI knew that was coming.
The hardener you add gives a chemical reaction,you should feel it getting warm if mixed properly.
jeez-way to throw a thread back on topic:joker:
-but that's exactly right- and if it gets real warm, it's too much hardener (and, iirc, the filler can be brittle after drying)
Well I hate to feed into a dirty subject. But it hardened up ok. Just took a little longer.
as long as it got hard its OK.body filler is Temp sensitive the colder it is the more you use. the hotter it is the less you use.OK evry one have fun with it............ArtieWell I hate to feed into a dirty subject. But it hardened up ok. Just took a little longer.
just mix in some viagra with the bondo that should help:joker::joker::joker:
The hardener gives a reaction,you should feel it getting warm if mixed properly.
Viagra is not as good as the claims the manufacturer makes. I took three of them last night, and only two worked!![]()
I tried to take one, it got stuck in my throat. I had a stiff neck all day.
/rimshot.
That sounds bad when you first read it.
