Built me a new tool
The two factory locating holes in the bottom. I can get you a pic later this evening if needed
here's a k frame and engine dolly I built for installation/removal of the engine and tranny.
I had the steel lying around so as of now I have 11.00 dollars in it. I lowered the bee down on it and it's solid as can be. Just thought I would share what do you guys think?
I think it's an awesome idea. So awesome I attempted to start making one I'm on disability and I need all the help I can get !the upright pins that go into the bottom of the K frame are these the holes that they go into ? Thanks for the great idea
Nice awesome job guys!! I love making my own tools. It's a whole new level of accomplishment when you build something with tools that you made.
Yes sir that the holes! I also added a piece of tubing on the front to bolt the front of the k member down through the radiator support brace hole. I’ll snap a pic of it and post it here.
Yeah that be awesome I have all the parts and pieces cut. I took a welding class.bought most of the steel at a welding shop, the pieces that drop and Hit the Floor. I think I've got about $22 so far. I'll send pics when I get it all finished one other question I had is I notice if you're looking from the jack to the front why is one of the uprights offset to the left? I really appreciate your time
your uprights look way further apart than mine from Center to Center is only about 8 and 3/4
The jack mount is offset because the engine and trans is offset to the right on the k member. The two uprights are adjustable side to side
I designed my build to accommodate both A bodies and B bodies as I have both.
Perfect I'm glad I went with the steel wheels also like you I'm trying to make it exactly like yours! I see it in action it looks awesome ! Thanks for the quick reply! looks like I know what I'm doing tomorrow mounting some Wheels finishing up the welding. Thanks again man Mopar or no car
Just thought I'd share pics Cuda Scott. Got everything level ,welded Wheels mounted I can easily go back and Tack the wheels , also have a set of Steel Wheels I'm going to try these first! just thought I'd share pics man thanks for your help again
Great looking engine/ tranny dolly. I will be working on disassembling my brothers 1967 Cuda notch later this year. I might "steal" your plans for the dolly when I get closer to engine removal. Thanks for posting.
Thanks to Cuda Scott I started working on mine this week moving right along, I'm going to try my wheels this way instead of welding them on so I can take it apart and store it nice and neat,
I'm wondering if I could build something like that with some beef pneumatic tires to roll across gravel :D
Pretty good idea probably sit a little taller to go for it
I'm developing a plan haha. I'm thinking about making the frame out of some 2x4s and reinforcing it with some metal brackets it will be a one time use thing for me so as long as its sturdy enough to hold the kframe and put some wheel barrel wheels on it . I actually just found some wheels at HF I just ordered them 23 bucks for all four! Jackpot!
