1973dusterkid
Watch This
Will the stock brake calpiars or a 71 duster work on a 73, if I use the same upper control arms and spindles.
I bought a 71 duster parts car SBP front disc the roter and brake caliper were shot.I want to put the disc on my 73 duster what would I need.
Well my 73 is sbp so all I would need to do is take the spindals off the 71 and order some calipers and roters from summit and put it on the 73.Both the 71 and 73 have sbp.
I have all needed for disc swap mins needing new roters and calipers.
I have all the disc brake parts for the 71 mins roters and calipers.
So if I buy stock replacement calipers and roter for a 71 it will fit becuse the whole font brake setup will be 71.
Will a fixed calipers fit were the org 71 had flooting calipers.
www.rockauto.com has the kits.
Honestly, I'd sell what you have and go with the BBP brakes with the EBC pads, 76+ calipers (bigger bore), and 11.75 rotors. It will stop you faster the KH setup every time. Plus (minus the pads themselves because you'll have to order them) you can get all the parts from a local autoparts store anytime.
