Al T
I recently bought a '68 Barracuda convertible that the previous owner did a home top install that did not end well. Is it possible to undo the mistakes that were made around the rear well? All the research I've done regarding installing a top, where the issue is is typically where the layout and installation begins. Looking at the attached photos, would I be able to remove the strip and staples and realign and restaple this area, hopefully tightening it up, or does the entire top need to come off. If it did, is it salvageable?
You can kind of see in the first photo there is approximately a 3/8" gap between the seam on the side curtain and the edge of the window section that the side curtain should cover. It looks like the window section needs to be "stretched" across the back and then the side curtain sections need to be pulled further around the back. Can this be done without unattaching it from the rear bow?
From the rear bow forward the top looks fine.
Any insight would be appreciated.
Allan
Allan
