Car won't start. Could miss Carlisle! Please help.
Electrical and Ignition
  1. domdart
    domdart FABO Gold Member FABO Gold Member
    242
    113
    Feb 14, 2015
    Johnstown, PA
    Local Time:
    11:21 PM
    My 68 Dart would not start this morning. I put a 72 340 in it last year. It always starts and runs fine. The last ride was on Sunday, no problems. Normally, I turn the key, it starts, I let go of the key and give it a little gas and it runs at idle fine. This morning, I turn the key, it starts, I let go of the key give it gas and it dies. I tried about ten times. It did the same thing every time. I plan on driving it to Carlisle Saturday morning. Any advice will be greatly appreciated. Thanks.
  2. mopardude62
    mopardude62 FABO Gold Member FABO Gold Member
    664
    497
    Oct 3, 2011
    Liberty, MO
    Local Time:
    10:21 PM
    It's the ballast resistor in the ignition circuit. They should have one at your local parts store. I carry a spare in the glove box at all times.
    • Agree Agree x 5
    • Like Like x 1
    • domdart
      242
      113
      Feb 14, 2015
      Johnstown, PA
      Local Time:
      11:21 PM
      Thanks for the reply. I work till 11:00. I'll pick one up on the way home. I keep an ignition box and a coil in the trunk with some tools. I will start carrying an extra ballast resistor.
      • Like Like x 1
      • toolmanmike
        toolmanmike FABO Staff Staff Member FABO Gold Member
        45,799
        29907
        Jan 18, 2006
        Iowa
        Local Time:
        10:21 PM
        x2 Sure sounds like a ballast resistor. The engine will continue running as long as you have the key in the crank position. Not good to do but as a test for a few seconds.
      • domdart
        242
        113
        Feb 14, 2015
        Johnstown, PA
        Local Time:
        11:21 PM
        I looked at my Summit Racing account. My coil came with a ballast resistor, so I already have one. I'll still pick-up an extra.
      • abodyjoe
        abodyjoe Well-Known Member
        20,250
        5080
        May 22, 2004
        Berlin,N.J. 08009
        Local Time:
        11:21 PM
        what ign system?
      • RedFish
        RedFish Well-Known Member
        23,794
        2508
        Sep 5, 2007
        Local Time:
        11:21 PM
        You can bypass the ballast resistor briefly. I once used a little piece of hose clamp to connect those 2 female terminals together so to drive the car to the part store.
        The coil would eventually over heat and some will spill their oil fill on the intake.
        • Agree Agree x 1
        • memike
          memike Super Moderator Staff Member FABO Gold Member
          49,728
          10814
          Jan 8, 2006
          on the hill
          Local Time:
          10:21 PM
        • domdart
          242
          113
          Feb 14, 2015
          Johnstown, PA
          Local Time:
          11:21 PM
          It has electronic ignition. I had the distributor from the 72 340 rebuilt.
        • WoodenNickle
          WoodenNickle Just Damn.....
          205
          43
          Sep 8, 2013
          Gray, GA
          Local Time:
          11:21 PM
          • Like Like x 5
          • abodyjoe
            20,250
            5080
            May 22, 2004
            Berlin,N.J. 08009
            Local Time:
            11:21 PM
            what box? please don't say the orange box.
          • domdart
            242
            113
            Feb 14, 2015
            Johnstown, PA
            Local Time:
            11:21 PM
          • Gamedog
            Gamedog Well-Known Member
            514
            618
            Jul 10, 2016
            Parker, CO
            Local Time:
            8:21 PM
            Definitely sounds like your resistor.
            Also - people will recommend you upgrade to the chrome/black box below:
            https://m.summitracing.com/parts/dcc-4120534
            I personally don't have any experience with either one, but lots of people run the box above with strong results.
            Good luck!
            • Agree Agree x 1
            • abodyjoe
              20,250
              5080
              May 22, 2004
              Berlin,N.J. 08009
              Local Time:
              11:21 PM
              • Agree Agree x 2
              • Like Like x 1
              • W-Edge
                W-Edge raceheads.ca
                107
                33
                Mar 8, 2017
                pointe des cascades , quebec
                Local Time:
                11:21 PM
                mopar part# 33000682 there a 16 in stock in canada , likely even more on your side of the border!
              • toolmanmike
                45,799
                29907
                Jan 18, 2006
                Iowa
                Local Time:
                10:21 PM
                Is that the resistor part number or the iggn. Box?
              • Daves69
                Daves69 FABO Gold Member FABO Gold Member
                4,597
                2716
                Feb 20, 2011
                WestOfChi
                Local Time:
                10:21 PM
                Double check your grounds. Clean and tighten bulk head connections and others as well.
                FWIW .........
              • W-Edge
                W-Edge raceheads.ca
                107
                33
                Mar 8, 2017
                Local Time:
                11:21 PM
                Resistor , it is for the starter on 83 to 93 jeeps(forget what model)it looks the same and has slightly less resistance then ballast resistor , have clients been using it for few years no problem gives close to 10v at coil instead of 9 to 9.5 , also depends on charging system...
                • Like Like x 1
                • W-Edge
                  W-Edge raceheads.ca
                  107
                  33
                  Mar 8, 2017
                  Local Time:
                  11:21 PM
                  Sorry I mentioned starter cause I didn t remember exactly what circuit it was for , it is actually for the fuel pump.
                • W-Edge
                  W-Edge raceheads.ca
                  107
                  33
                  Mar 8, 2017
                  Local Time:
                  11:21 PM
                  List price in canada is 13.15$
                • stillsteamn
                  stillsteamn Active Member
                  32
                  10
                  Jul 3, 2014
                  Minnesota
                  Local Time:
                  10:21 PM
                  Where is this ballast resistor located on the vehicle?
                • diymirage
                  diymirage HP@idle > hondaHP@redline
                  17,232
                  10471
                  Oct 12, 2012
                  michigan
                  Local Time:
                  11:21 PM
                  you cant try to use the balast resistor from the wiper motor to get you home
                • W-Edge
                  W-Edge raceheads.ca
                  107
                  33
                  Mar 8, 2017
                  Local Time:
                  11:21 PM
                  duster engine bay - Google Search:
                  White thing with two black prongs right above the w wash tank(above in pic actually behind in real life , damn those 2d pics) , that is the stock location and in this example it is crooked!
                • stillsteamn
                  32
                  10
                  Jul 3, 2014
                  Minnesota
                  Local Time:
                  10:21 PM
                  Yes, of course, thanks! I better get a spare.
                • W-Edge
                  W-Edge raceheads.ca
                  107
                  33
                  Mar 8, 2017
                  Local Time:
                  11:21 PM
                  Chrome box p4120534 list is 81.45$cad there are 4 available in canada , need better coil , have accel super coil on mine!
