Carb?'s
svtcobra94
New Member
I've got a 360 with a mild cam 30 overbore pistons along with 340J heads, now my question is what would be the best carb to use? I should also mention compression ratio is close to 11:1. Any help would be great thanks.
I,m running a 750 holley with v.s on my stroked 340(372)452hp with x heads P/P,rpm airgap with headders.When my engine was dynoed the builder(old mopar racer)recommended the 750v.s for best performance.Oh ya my cam is XE284H.All in front of a 4 speed.
Your engine description is very vauge and leaves out intended useage.
In general, I agree, a 750 will cover 90% of all applications.
How mild a cam is it??..11 to 1 comp. i'd run as much cam as possible..
Camshaft Technical Details
Intake Valve Lift 1.5
Exhaust Valve Lift 1.5 .524"
.540"
Intake Valve Lift 1.6
Exhaust Valve Lift 1.6 .558"
.576"
Intake Duration at .050"
Exhaust Duration at .050" 228°
232°
Lobe Separation Angle 110
Intake Opening at .050"
Exhaust Opening at .050" 7° BTC
49° BBC
Intake Closing at .050"
Exhaust Closing at .050" 41° ABC
3° ATC
Min. Suggested Cylinder PSI 160
Sweet Spot RPM 2200 - 5600
The car is meant to be a daily driver. The motor is together and has about 230miles on it. We were just looking what way to go on carb selection.
