Cool. Not the "S/S" type, of course. But I like 'em!Whaaaaaaaat!?!
For sale by the way.
Those are good looking tires I don't think you will be disappointed. What size did you get?I just ordered the nittos...
318 has valves that will fly and I can compare our 60-foot times...
sure thing...…I just ordered the nittos...
275/60/15'sThose are good looking tires I don't think you will be disappointed. What size did you get?
you'll have a lot more tire diameter than me. I bought 235/60r15's275/60/15's![]()
Imo bigger isnt always better. Just big enough to give you the proper traction is perfect anything bigger is just a waste of weight!you'll have a lot more tire diameter than me. I bought 235/60r15's
Correct. Taller tires will hook up better. They can "look" better by opinion. But if the shorter tire is hooking, your statement is correct.Imo bigger isnt always better. Just big enough to give you the proper traction is perfect anything bigger is just a waste of weight!
my first set were MH racemaster back in early 80's , they were bias ply, decent hook. went to the BFG drag tire and couldn't hook worth a damn, ended up with Micky T's and haven't looked back, I'm getting ready for set 3 shortly.Been using MT drag radials for over 8 years p.s.i. set at 16lbs with my 416 car 60' in the low 1.40's with the 360 mid 1.50's..used 1 pair of B.F.G. drag radial's totally USELESS duster would spin them halfway down the track..this by the way is with nothing more then H.D. leaf springs a pair of cheap drag shocks and pinion snubber![]()
Well besides traction my thinking was trying to get the tallest Tire I could to take advantage of my new 354 gears...Correct. Taller tires will hook up better. They can "look" better by opinion. But if the shorter tire is hooking, your statement is correct.
I would think you'd have plenty of low end grunt with the stroker. Especially with a detuned cam.Well besides traction my thinking was trying to get the tallest Tire I could to take advantage of my new 354 gears...
I feel like I've got plenty of horsepower on tap for all the fun I need...
Pie crust is what I should have typed. That being saiOld school cheaters.
Weight over your back tires isn't necessarily a bad thing...Imo bigger isnt always better. Just big enough to give you the proper traction is perfect anything bigger is just a waste of weight!
That is true.Weight over your back tires isn't necessarily a bad thing...
LOL..... post 66 - but tires (rotating weight) is the worst way to add it...That is true.
Or a heavier Dana 60 axle over the back tires...LOL..... post 66 - but tires (rotating weight) is the worst way to add it...
It's why many run drag lite rims, and for certain classes add weight in the trunk or pickup box to meet the weight requirements
