Confirm my luck TA heads?
Discussion in 'Small Block Mopar Engine' started by NorthernNYMOPAR, Jun 10, 2018.
  1. NorthernNYMOPAR
    NorthernNYMOPAR Member
    24
    13
    Nov 3, 2017
    Adams
    Local Time:
    12:19 PM
    Ok I bought bunch of engine / car parts from a guy doing swap, it was 318 that had a bad build, resulted in flat cam cracked / burned pistons. I need miscellaneous parts for a build I was doing including the adjustable rocker arms. Well thought I had lucked out when I found out heads were 2.02 but had a ported set I was using. Well went to put rockers on my heads and thought WTF they won't line up then I realize they have a bunch of offset on one side, and then look at head and realizing that I believe I got super luck and have a set of TA 340 6-pack heads. They are a U casting and here are pics of the rockers and pushrod holes.
    • Like Like x 5
    • Agree Agree x 2
    • MOPAROFFICIAL
      MOPAROFFICIAL Well-Known Member
      2,790
      1760
      Jun 1, 2016
      breakwater
      Local Time:
      9:19 AM
      TA heads, sell them to me so I can turn them into polished gold. I'd port those sob's to flow gang busters.
      • Like Like x 4
      • JBurch
        JBurch Well-Known Member
        1,528
        621
        Oct 17, 2009
        Owego, NY
        Local Time:
        12:19 PM
        You struck a gold mine............
      • Alaskan_TA
        Alaskan_TA Well-Known Member
        4,078
        1841
        Nov 12, 2004
        PA
        Local Time:
        12:19 PM
        I know a T/A & one AAR owner looking for single heads to fix their engines.
      • Alaskan_TA
        4,078
        1841
        Nov 12, 2004
        PA
        Local Time:
        12:19 PM
        The adjuster screws are from a 273, but the rocker arms & heads look right.
      • nm9stheham
        nm9stheham Well-Known Member
        9,743
        2164
        Dec 20, 2013
        Waynesboro, VA
        Local Time:
        12:19 PM
        If you're posting this to make others jealous, it's working LOL
        • Agree Agree x 3
        • stroked340
          stroked340 Well-Known Member
          4,822
          1116
          Jun 14, 2014
          mass.
          Local Time:
          12:19 PM
          Only valuable to someone looking for them to restore a sixpack motor..other then that they're just 2.02 heads nothing special..
          • Like Like x 2
          • NorthernNYMOPAR
            24
            13
            Nov 3, 2017
            Adams
            Local Time:
            12:19 PM
            Agreed unless restoring or porting and using the extra meat just a set pf 2.02, they were on a mild 318 build guy didn't even know they were 2.02, thought that was the bonus, then bummed when rockers didn't fit then I started thinking why, I've had stamped, cast, aluminum rockers, X and W2's, but hadn't seen a set of these. Just cool to have a set.
            • Agree Agree x 1
            • rumblefish360
              rumblefish360 so close yet so far away
              33,082
              5188
              Jun 21, 2005
              New York, on a Island
              View My Photos
              Local Time:
              12:19 PM
              And he will be saying;
              • Like Like x 1
              • Alaskan_TA
                4,078
                1841
                Nov 12, 2004
                PA
                Local Time:
                12:19 PM
                The heads are easier to find than the rocker arm set.
                Rocker set could bring 1200 pretty easy.
              • Bulldozer
                Bulldozer Well-Known Member
                15,533
                1660
                Oct 16, 2011
                why
                Local Time:
                11:19 AM
                exploit them for every penny you can get out of them.
                • Agree Agree x 2
                • Blind Squirrel
                  Blind Squirrel Well-Known Member
                  397
                  101
                  Oct 1, 2015
                  Pacific NW
                  Local Time:
                  11:19 AM
                  Exploit? Isn't that Karma's evil step sister? But wow, nice luck!!!
                • Bulldozer
                  15,533
                  1660
                  Oct 16, 2011
                  why
                  Local Time:
                  11:19 AM
                  yeah , try and buy just about anything for a B body and you'll find out exactly how people exploit parts.
                  it's how the hobby works these days
                  • Agree Agree x 1
                  • diymirage
                    diymirage HP@idle > hondaHP@redline
                    14,355
                    6643
                    Oct 12, 2012
                    michigan
                    Local Time:
                    12:19 PM
                    If you can afford a B body, you can afford to be exploited
                    :poke:
                    • Like Like x 2
                    • rumblefish360
                      33,082
                      5188
                      Jun 21, 2005
                      View My Photos
                      Local Time:
                      12:19 PM
                      Corrected
                      :rofl:
                      • Like Like x 3
                      • stroked340
                        4,822
                        1116
                        Jun 14, 2014
                        mass.
                        Local Time:
                        12:19 PM
                        Oh so I guess its ok to screw people over on parts prices:rolleyes::rolleyes:..
                      • abodyjoe
                        abodyjoe Well-Known Member
                        19,291
                        3430
                        May 22, 2004
                        Berlin,N.J. 08009
                        Local Time:
                        12:19 PM
                        i'd flip them those bitches to fund other parts of my projects..
                        • Agree Agree x 4
                        • Like Like x 2
                        • yellow rose
                          yellow rose Doctor of Thinkology.
                          15,415
                          12016
                          Jun 19, 2015
                          Living on the razors edge
                          Local Time:
                          9:19 AM
                          Of course you would. There's lots of great 360's out there that need a home.
                        • abodyjoe
                          19,291
                          3430
                          May 22, 2004
                          Berlin,N.J. 08009
                          Local Time:
                          12:19 PM
                          damn right.. hell if the rockers are really worth 1200 alone then thats a good amount towards a stoker kit or some eddy heads....
                          • Like Like x 2
                          • yellow rose
                            15,415
                            12016
                            Jun 19, 2015
                            Local Time:
                            9:19 AM
                            The sad thing is...the rockers are probably worth that if they aren't beat to shit.
                          • rumblefish360
                            33,082
                            5188
                            Jun 21, 2005
                            View My Photos
                            Local Time:
                            12:19 PM
                            And they’ll be a plenty who won’t care of they are.
                          • 70aarcuda
                            70aarcuda Master Hoader of SBM FABO Gold Member
                            13,952
                            2035
                            Jan 16, 2005
                            las vegas
                            View My Photos
                            Local Time:
                            9:19 AM
                            Rockers can home to RAS to be rebuilt.
                          • replicaracer43
                            replicaracer43 Old school member
                            3,732
                            2151
                            Oct 10, 2008
                            View My Photos
                            Local Time:
                            11:19 AM
                            The REAL silly part of it is, with the valve covers on, no one will have a clue what type of rocker is on there. LOTS of high dollar T/As and AARs don't have the correct head/rocker assy on them.
                            • Like Like x 2
                            • 70aarcuda
                              13,952
                              2035
                              Jan 16, 2005
                              las vegas
                              View My Photos
                              Local Time:
                              9:19 AM
                              Before I would buy a HIgh Dollar AAR or TA ....you would be taking the valve covers off.....pretty simple...in fact if you remove the oil cap and peak in....you can tell if it has the correct rockers on it....and if it does not have the correct rockers...then it does not have the correct heads on it...
                              • Like Like x 1
                              • Bulldozer
                                15,533
                                1660
                                Oct 16, 2011
                                why
                                Local Time:
                                11:19 AM
                                hey let's get one thing straight , I practically give shit away just to find it on eBay. now , 1500.00 for a B body am/fm radio? there's exploitation for ya !!
                                • Like Like x 1
                                • Agree Agree x 1
