Coolant Temp and fuel gauge pigtails
TheDuke
Member
Houston, TX
short and sweet, I’m looking for those pigtail connectors that attach to a 72 Duster fuel tank and a 383 mopar temp sender. It’s been a pain in the butt to find these. Every similar pigtail (GM) is too small. Could I just put an eyelet on the wire and sandwich it between two nuts on the pole??
Help me Obi Wan Kenobi, you’re my only hope...
These Chryslers senders have #10 studs. #8 terminal would be a forced fit. The coil has nutted terminals on studs. That would work at these senders too.
I asked around and found a member with several rally inst' panels. The noise suppression capacitor on that inst' panel has a 90 degree X #10 terminal. The wire is only a couple inches long, is steel instead of copper, it isn't fully weather booted like OEM had at these senders but... it fits. A e-body inst' panel has several of these #10 terminals but that doesn't make them any easier to find. For example only... DASH GAUGE VOLTAGE LIMITER HARNESS 70-74 CUDA CHALLENGER ORIGINAL MOPAR E-BODY | eBay
