femtnmax
360 engine with oem cast crank, oem front damper, Ross forged pistons, eagle rods, and steel flywheel. Externally balanced including damper and flywheel mods.
The new owner of the engine installed a flexplate for auto trany. Can he take the flywheel and flexplate and have them weight matched? Or does the crank need to come out and rebalance the rotating assy using the piston/rod weight numbers, front damper, and flexplate?
Thank you in advance.
