Cross ram air bells help
Interesting. The ones he sold me were originals from his stash of old mopar stuff. Kramer also gets his from crossram.
Funny, he said he "might be able to scrounge a set of originals" that needed rescreened. In talking to him, he says he sold the tooling for the '64-'65 Max Wedge/Hemi crossram oval air cleaner to A&A Trans - said it was too labor intense and too detailed to keep trying to produce them. I also learned the rubber seals I referred to were optional - he said everyone was doing their own thing with seals or not seals, etc. He suggested the aluminum crossram plate that attaches to the underside of the hood. I was under the impression two holes, slightly larger than the inner sloped part of the stacks/bells was the way to go but he said a lot of guys simply cut a large hole under the Hemi scoop. I'm amazed at what I'm learning.
And some racers just let the scoops protrude into the scoop space and called it good. Go figure.
Ray Barton Crossram. Not sure if that intake is taller than other crossrams or not.
Ok, thanks. I'm using a Mopar Performance piece. It would be interesting to know if the two are different heights as Ray Barton stuff is geared more toward performance. Does the Barton intake have a raised carb base? If it were a titch higher than the MP parts, that might account for the interference.
The Mopar manifold I believe is higher than the original crossram.
Not a dumb question. If memory serves me, about an inch difference. I had the Mopar reproduction on my 572 hemi in a 64 Savoy and it barely fit under the scoop found on those super stock cars.
I bought a pair from Mancini about a year ago. Sadly, I am not able to run them on my 1969 Barracuda because they are a tad too tall and they are both touching the inside of the hood scoop. I would run them if I could come up with a way to get the needed clearance.
Mine had spacers under the K frame mounting. They did that for the hood clearance. I still have some if you need the specs.
I just spoke to Brian at Crossram Connection today about that very thing and he said the spacers were 2"x2" and 1/4" thick. Would be nice to corroborate that, you know, trust but verify. Yes, please, what 'cha got?
I have a repro hemi k from
Al Debevic
It came with mounts and spacers.
It’s packed away, but I could dig it out and measure spacers if needed.
