What are these holes for?
With all this name dropping and trumpeting all I could think of was this:Now this is entertainment![]()
Ahhh, where he broke through. Gotcha.Bolt hole recess.
"Those early applications demonstrated how well-managed tract turbulence accommodates extra-lean air/fuel mixtures, and how swirl can improve combustion quality to reduce a mixture's sensitivity to detonation. The more mixture activity that occurs, the better the fuel remains in suspension and the better the mixture burns. The faster a fuel burns, the less ignition timing is required to produce equal power. And because wet fuel doesn't burn, or burns unevenly at best, swirl helps create and maintain a fully atomized air/fuel mixture"
Thanks. His case is an extreme use of the head. He is limited by class. It is an excellent use of the head.
Now let’s do similar to an aluminum head.
Just the way u were bragging them up. KimYes but nothing exotic. An Honest question Kimmer. Where did your presumption come from to think that they needed to be Exotic to make power?
“I don't think so”
Oh I do, so very much. You keep pushing the OE iron head. That’s fine. So far you claim it makes more power than a W2 and it’s better than an aluminum head.
You’ve been shut down before and continue to argue against the facts.
Enjoy your night.
Now that you realize how plain they really are doesn't now make you curious as to how he's making power?
I'm not pushing anything. If you think this discussion is about heads you're sadly mistaken as his heads were used to prove a point that you now want to totally ignore. If think airflow is everything than how come Dan makes power with the stuff you think isn't worthy of your time. There's more to making power than just airflow. If you ignore the fueling aspect then an engine is just an air pump and you need bigger heads. Oh and if you build an engine with all that exotic stuff and it doesn't make the power you think it should then it needs bigger heads....
Not really, he obviously has a handle on everything, especially chassis. I bet his stroker makes no more than 600ish hp and that's just an off the cuff guess. Don't get me wrong, it's an amazing and rarely replicated feat, Lord knows I couldn't do it or even tell you how. I do know how much a good chassis is worth, = priceless. J.Rob
Not at all. KimNow that you realize how plain they really are doesn't now make you curious as to how he's making power?
Incorrect and if you have been reading my posts on this subject (not just cylinder heads) you would have never ever wrote what you wrote.
Let’s revisit his head choice and what he could do by moving away from OE iron. Would be to with aluminum if he could?
Yea... thought so...
This is the basic montra people sing and while there is truth to this, it is also what should be the beginning, not the whole story."People often talk about engines as being air pumps but if you only consider them from that point of view you miss the interaction of the fuel and thats the real reason for an engine isnt it. its actually there to convert chemical energy into mechanical energy and to do that you have to follow the chemistry not just the air pump"
Incorrect on both accounts.Lets revisit the fact that he's making power with the stuff you all think you cant. Your still caught on airflow.......
Sure your pushing iron swirl port heads. You can’t get off the head itself. You have shown how this guy ported and combinationed the engine package to go fast. Very cool by the way.I'm not pushing anything. If you think this discussion is about heads you're sadly mistaken as his heads were used to prove a point that you now want to totally ignore.
By this, it seems to me that you haven’t read or simply taken the time to understand what I have previously posted here at FABO. Thanks for not reading and assuming poorly.If think airflow is everything than how come Dan makes power with the stuff you think isn't worthy of your time. There's more to making power than just airflow. If you ignore the fueling aspect then an engine is just an air pump and you need bigger heads. Oh and if you build an engine with all that exotic stuff and it doesn't make the power you think it should then it needs bigger heads....
WTF is wrong with you?!?!
Then you say his heads were used specifically to prove a point, which remains unknown except, maybe, that he can go fast with factory iron?
You say I ignore these heads, that power is more than just the heads? Obviously you don’t read my replies left here at FABO. In other words, your more than just wrong but dead nutz balls on accurate wrong.
Double negative! If I thought so much, the. Why am I sitting on this stack of the same cylinder heads and this rotating assembly designed for a 352 cid?
View attachment 1715676937 View attachment 1715676938 View attachment 1715676939
I guess someone isn’t reading.... Hysteric....
Hello?!?! Hysteric.....
You keep throwing **** my way assuming, misquoting, twisting my words, out right lies, your caught red handed or not reading and understanding what I write but seem obsessed on pushing bullshit on the thread.
It ain’t sticking to this teflon coated fish.
Third time tonight!!!!
Shutdown!!!
Care to go for more?
I’m bored with proving you wrong three times in one night. Are you this kind of type of weirdo that likes abuse?
Seeiously!
That and he keeps pointing to the thread on the other board. This build shows really well what this guy can do. That doesn’t mean we all here are capable of mimicking his effort. If it was that easy, we all would be doing it. I also find the $1600 price tag interesting as the thread is 2015. So, $1600 plus the price I have to pay for the heads (And acco. parts?) plus shipping to and from the porter.He's read all the magazines which makes him smarter than all of us, but he's upset we don't realize it and treat him accordingly for it.
It would be neat if he'd at least state something instead of playing "gotcha" with arguments no one is making.
If you look close at the heads he posted you’ll notice they have very little swirl. In fact, much less than I use on my street/strip stuff and I really HATE swirl. It is a required evil sometimes.
If you also notice, the guy said he stuck his piston .080 out of the hole. Been advocating for getting the pistons out of the holes since right after HS. I’ve never had to go that far out, but I would if I had to.
