33IMP
Create a burnout with TWO tires.Man that was epic I love that video!! Thats gonna be hard to top!! I gotta get creative i guess!
Hey, I used two tires! Just not at the same timeCreate a burnout with TWO tires.
North Dakota Style....Best I can do Willrun. lol
She's running good I have an issue with when it sits for a day or so it takes a bit to get the oil pumped up again and not sure why. changed the filter 3 times and still the same issue.North Dakota Style....![]()
loved it! that blueprint running all right?? Maybe raise a little Cain ???
Me ether I'd fall over the handle bars and kiss the pavement.Im impressed actually! No way I could physically do that ! Haha
What weight oil are you using? Maybe the bearing clearance is tigher and you need thinner oil when it's cold? Just a guess!She's running good I have an issue with when it sits for a day or so it takes a bit to get the oil pumped up again and not sure why. changed the filter 3 times and still the same issue.
So she sits till I find the problem.
Loved your burnout that was great....
using 15-40 as recommended by BluePrint as one choice but good idea I'll go with a lighter weight oil.What weight oil are you using? Maybe the bearing clearance is tigher and you need thinner oil when it's cold? Just a guess!
Id check with @Johnny Mac and see what he thinks but that would make since to me. If its not getting pressure when cold maybe a 5w would be better than a 15w.using 15-40 as recommended by BluePrint as one choice but good idea I'll go with a lighter weight oil.
Cars never been started in anything lower than 55* But will check with Johnny for sure.Id check with @Johnny Mac and see what he thinks but that would make since to me. If its not getting pressure when cold maybe a 5w would be better than a 15w.
Remind me, flat tappet cam? Still break in oil?Cars never been started in anything lower than 55* But will check with Johnny for sure.
I'll PM ya.Remind me, flat tappet cam? Still break in oil?
How long is "takes a long time to show oil pressure? Mechanical gauge?
