Dash Panel Heater A/C controls
68cuda05gto
north platte
I am in the middle of redoing my dash in my 68 barracuda, i have the dash and firewall stripped, i am installing a 6.1 hemi into the car and going to use my factory heater core and a/c evaporater kit but wondered if there is a universal or aftermarket temperature control kit out there i can use to operate my cold to hot and vents to defrost and floor controls using the original vacuum style controls, or any other suggestions or pics of what other people have done on custom panels? any help would be appreciated!
I dont know of another controller that will operate the vacuum servos etc on that plenum. Even the factory 73 up parts are a lot different. You might graft that controller into you instrument paenl which would get rid of the push buttons but you would need the graft in matching plenum also.
I've seen the aftermarket ( Nostalgic Air ) controller grafted into the rallye bezel but again it was the entire a/c package install.
That's. Good idea. I will use my original heater controls jus cut holes out for the push buttons and a slit for the temp arm
