Hey guys I put a set of bbp Discs on my wagon and I have been trying to figure out an issue that I've been having.
I replaced the calipers, rubber lines, master cylinder (was previously upgraded to a dual stage one before I got it) banjo bolts, rotors were turned, and new wheel bearings too.
When I go to bleed the fronts, you pump the pedal a ton to build a tiny bit of pressure and when you release the bleeder not much comes out and you have to pump it up a ton again. Then I would go for a spin around the block and the pedal gets super firm and the front calipers start dragging super hard to where you cant spin the wheel if it were jacked up off the ground. If I leave it over night, they release. It actually first did this with the old master and calipers, so I replaced the calipers first and when that didn't fix it I replaced the master too.
Still having that issue and I'm thinking it might be the new banjo bolts.. Here is a picture of a new one from Orielly's and an original from a 75 Dart. The original is on the left, see any issues? I measured the 'neck' where the hole is and the original is slightly smaller at .397, the new one was .405. Also looks like the factory ones have a tapered hole and a larger inner diameter too...
