Do Early A-Bodies Truly Have Lower Profile Hoods?
dibbons
La Paz, B.C.S., Mexico
The first generation Ford Mustang hood does not seem to me to stick up any higher from the ground than the first generation Barracuda (although I have never measured or compared them side-by-side). But didn't Chrysler claim the six cylinder motors were manufactured at a 30 degree angle to allow for a more streamlined profile?
Anyone have both of the above vehicles at home and can do a comparison for us? Thank you.
Here is a quote from one of many source articles:
The inline engine was given the Slant Six name because of its unique, 30-degree tilt toward the passenger side of the vehicle. This design was implemented for several reasons, according to Chrysler’s original 1960 press release:
  • The center of gravity is much lower than in upright engines
  • Increased clearance for use with the Plymouth Valiant’s low-profile hood
  • Engine accessories are more accessible
OnAllCylinders – Top 10 Engines of All Time (#6): Chrysler 225 Slant Six
The Ford I6's were much shorter. I don't have outside dimensions but the stroke and rod length between the two is quite an bit different. The Slant 6 was a long stroke, long rod torque motor.
Slant 6 stroke: 3.40 Rod length: 6.69
Ford 2oo 6 stroke: 2.94 Rod length: 4.71
The slant six was developed before the Mustang and Barracuda were even thought about. Look at 1960 Valiants and 1961 Lancers, that is what it was developed for...
I think it's more for the distance between the K frame of that vintage A body, and the underside of the hood. Not hood to ground. I am setting the engine in my early A back and down for the same reasons, but had to modify the K frame and trans crossmember to do what I want.
Minor point, Slant Six strokes were 3 1/8" for 170's, 3.64" for 198's, and 4 1/8" for 225's. The 170 "G" block was about an inch shorter in height than the 198/225 "RG" block.
If you put a slanty225 on the garage floor, and stand it up vertical, Its monster tall. They would have needed a pretty big powerbulge to cover it. Probably not the best idea for a grocery-getter.
Those early As do have a pretty short hood to K dimension, which you will find out PDQ when you put a V8 in there with a high-rise intake.
In that case, maybe the slant is just so it fits under normal/conventional/standard hood (not a "lower profile' hood per se).
