I will, Half inch is huge on the top. If works will not have to "scoop" my hood.Won't hurt (too much) to try... But pretty sure oil pan will be resting on center link...
Be sure to let us know though...![]()
A thought however it might raise alignment issues.Those are Schumacher conversion mounts that they designed to use the thinner biscuit insulators. If you need hood clearance, I've seen cars with the k-member spaced down.
